overheating 2009 clubman
Old May 28, 2013 | 02:45 PM
chappy8599's Avatar
chappy8599
I was stuck in trafic today and my 2009 clubman temp light came on red. i had the ac on and it just turned 60000. any help.
Old May 28, 2013 | 03:08 PM
countryboyshane's Avatar
countryboyshane
When your engine is cold where does the coolant level sit at in the coolant resevoir? Check that first.
But otherwise, try to avoid blasting your AC when you're at a dead stop in the heat of summer. That is the worst possible condition for a car's cooling system. The MINI runs a bit hotter than most cars as it is so don't push it.
Old May 28, 2013 | 05:52 PM
chappy8599's Avatar
chappy8599
It was only 70 out and my ac wasn't blowing that cold when stopped . I wish it had a temp gauge and not just the light.
Old May 28, 2013 | 10:08 PM
nrfitchett4's Avatar
nrfitchett4
Thought running the a/c on max actually helped with cooling?
But definitely check the coolant level, then the thermostat.
Old May 28, 2013 | 10:57 PM
alexs3d2's Avatar
alexs3d2
What helps is if you run the heater... The heater is essentially an extention of the cooling system, so turning that on increases the heat exchange rate (like a secondary radiator).
But do check the coolant level. The plastic water pumps tend to crack around the shaft and drip coolant.
Old May 29, 2013 | 08:08 AM
chappy8599's Avatar
chappy8599
It was the electric fan 400$
Old May 29, 2013 | 09:46 AM
countryboyshane
Ah that makes sense. 70 degrees is not extreme
Old May 29, 2013 | 11:36 AM
Glad you found the problem and it was not the head or something worse. Also make sense, the fan just locked up and then when stuck in traffic peaked the temp warning light, because you could not cool the additional heat. How long was it hot for?
Was this on a Clubman "base" or justa? Fits all R56+ Base models. If so we had them here.
http://www.ecstuning.com/Search/SiteSearch/17422754854/
Old May 29, 2013 | 12:46 PM
chappy8599's Avatar
chappy8599
It was only hot for a moment as soon as it went hot I pulled right over and **** it down. It's a clubman base.
The_Kid
Sep 14, 2015 03:41 PM
Panik
Sep 9, 2015 08:36 AM
Ntety
Sep 2, 2015 08:39 PM
TrueEddie
Sep 2, 2015 11:43 AM
