R50/53 Where to get CV joint / axle assembly?
Old May 26, 2013 | 03:51 AM
mrbean's Avatar
mrbean
I'm in the middle of a suspension rebuild and I did a number on the threads on the outer CV joint while trying to break it free from the hub. So, it looks like I'll need a new CV joint or entire axle assembly. Any suggestions on where to get one? The only ones I can find online are the $500 OEM axles or the $50 el-cheapo rebuilt ones. Is there any OEM quality parts that don't cost an arm and a leg? I used to be able to buy brand new GKN axles at a reasonable price for my VWs, but can't find one for the MCS.
Old May 26, 2013 | 04:21 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Of those whom I have heard used non-OEM ( ebay, ect) they didn't last long maybe a year or so. In some cases where the MINI was lowered. they failed as soon as 3 months....You'll need tranny fluid to top off too.
Old May 26, 2013 | 04:31 AM
-=gRaY rAvEn=-
Moderator
Found this....http://www.ebay.com/itm/PAIR-NEW-COMPLETE-FRONT-RIGHT-LEFT-CV-DRIVESHAFT-ASSEMBLY-MINI-COOPER-S-/290702607232?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACooper&hash=item43af39c380&vxp=mtr
If you go this route, at least pick up new OEM output shaft seal....
Old May 26, 2013 | 05:01 AM
mrbean's Avatar
mrbean
Thanks for your help.
I was able to find a GKN CV joint (not the whole axle) at partsgeek for less than $100. I've had really good luck with them in the past. Since I have the 200 HP JCW and I'm installing H-sport springs, the risk of using low price/quality parts is just too high.
Also, just ordered some trans fluid. It's about time for a change anyway.
One last question; how easy is it to pull the axle from the trans? Do I need a slide hammer or can I just pull it by hand?
Thanks!
Old May 26, 2013 | 06:14 AM
-=gRaY rAvEn=-
Moderator
Axle and bearing assembly should come out aok by hand.
What are the conditions of the inner and outer boots ? The MINI boot kits come complete with grease if the boots are old/leaking.
Old May 26, 2013 | 06:26 AM
BlwnAway's Avatar
BlwnAway
Just use a large screwdriver or small prybar up at the trans. housing where the axle slides in, actually takes minimal force.
Old May 26, 2013 | 09:53 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by mrbean
I'm in the middle of a suspension rebuild and I did a number on the threads on the outer CV joint while trying to break it free from the hub. So, it looks like I'll need a new CV joint or entire axle assembly. Any suggestions on where to get one? ....
Try the Driveshaft Shop. Nice product and I found mine from a vendor on eBay that was cheaper than direct.
///Rich
Old May 27, 2013 | 08:34 AM
GreekDrifter91's Avatar
GreekDrifter91
you can try german auto parts . com they have great prices and are always fast and for me they are only one state over so delivery is litteraly next day. but it looks like you sorted everything out all ready.
OutMotoring
Mar 3, 2017 06:29 AM
gknorr
Dec 26, 2016 09:38 AM
vulkandino
Oct 31, 2015 08:29 PM
pahg
Oct 5, 2015 11:50 AM
gknorr
Oct 1, 2015 09:20 AM
