R50/53 question about wheels!
Old May 23, 2013 | 07:56 PM
DTMR's Avatar
DTMR
Im looking at some enkei 92 cuz they are affordable and made in Japan for my r53 but the biggest I found is 15x8 so far, Is that too small and would that effect anything negatively? Like the handling? they are 4x100 with a 25 or 38mm offset
Old May 23, 2013 | 08:03 PM
Braminator's Avatar
Braminator
As long as they clear the brakes and you have the right tire you should have zero issues. Being they are lighter then stock you will feel that difference in handling and performance. I would use the 38mm offset because IMO 25mm will stick out to far.
Old May 23, 2013 | 08:07 PM
danjreed's Avatar
danjreed
Just realize that your bigger (taller) sidewall will have more flex in the corners. (that is, if you have 16's now..)
Also make sure the clear the center bore. If not, you'll have to get them machined out.
And, as noted - check brake caliper clearance.
Old May 23, 2013 | 08:22 PM
DTMR's Avatar
DTMR
they also have ESM wheels which are made in the USA and I can get them in 16s
DTMR's Avatar
DTMR
I love that mesh design and Im trying to find a good wheel not made in china that has that bbs rs look
G1HQ
Dec 7, 2015 02:23 PM
thebordella
Aug 31, 2015 01:37 PM
Mini'mon
Aug 16, 2015 04:15 PM
ki7hy
Aug 12, 2015 07:07 PM
nomar116
Aug 10, 2015 11:24 PM
