R50/53 Newbe Being Tortured With Misfires
Well....here I am looking for a little expertise to help me diagnose a Cylinder #1 Misfire on a 2002 R50. I can get it to redline in any gear if I feed it gas slowly. If I give it any significant throttle it starts to misfire. If I back off quickly when it starts the DME can recover and adjust the timing and mixture, without issue, but If I keep the throttle down it will Flash the CEL light, lite the DSC light and continue to run rough until I turn it off and start it again which resets the DME Computer.
New Plugs, Tested Wires, New Cam Position Sensor, New Fuel Filter (WOW Dirty). I'm kinda thinking there is dirt in my injectors which are original (127K Miles). It was doing this prior to a filter change but man was there a significant amount of dirt in that filter. I tried to clean it out as best as I could but maybe not god enough for the injectors.
I gave her a dose of sea form to clean up any carbon, but I cant image carbon or a burned valve when there is no problem on slow application of the throttle.
On the Plan for Monday
Braminator I noticed you are the King of this forum so thank you for the reply. It goes into the shop for the leakdown on Monday cause of the hundreds of tools I have that isn't one of them...Audi's never have valve or compression issues.
Until Monday I cant sleep knowing a Mini is kicking my axx
. I cant imagine a valve because the behavior isn't all through the power band...but only on acceleration.
It started while I was driving it one day a few weeks ago and has never stopped. I really think there is dirt in my injectors. When I opened the fuel filter I shix myself looking at all the dirt. It was virtually impossible to get it all and that has compounded the problem. After that harder to start too.
I don't think these are cheap and I'm not sure cleaning is the answer. They are original and looked pretty skanky on the exterior when I pulled them.
Stay tuned. Thanks
. I cant imagine a valve because the behavior isn't all through the power band...but only on acceleration.It started while I was driving it one day a few weeks ago and has never stopped. I really think there is dirt in my injectors. When I opened the fuel filter I shix myself looking at all the dirt. It was virtually impossible to get it all and that has compounded the problem. After that harder to start too.
Stay tuned. Thanks
dutchhome
Sep 30, 2015 07:17 AM
ShadyCoop
Sep 20, 2015 08:57 AM
