New to me Mini, engine cut out
Old May 12, 2013 | 11:43 AM
tbearmini's Avatar
tbearmini
First post to the forum. I have an '06 R50 5-speed that I just purchased with 107k miles. It's in pretty rough shape - no apparent maintenance - so I'm going to nurse her back to health. I searched the forum and found out about the stall after starting the car but my issue isn't that.
Anyway, changed oil, plugs/wires, coolant, and transmission fluid. Went for a quick spin a few minutes ago and the engine cut out when I came to a quick stop at the end of my subdivision (about 1 mile from my house). It started right back up and off I went. When I got home, the fan ran for a couple of minutes at shut off which it has never done before.
Code reader shows no codes. Expansion tank has plenty of coolant so it doesn't appear low.
Any thoughts - all I can think of is no fuel. I have a new fuel filter on the way but I would appreciate any help or things to look for.
Old May 12, 2013 | 11:47 AM
tbearmini's Avatar
tbearmini
Also, just checked to see what battery is in there and it says EconoPower and is marked "Recon" (reconditioned?). Any chance that's the issue?
Nevermind - just tested battery and it was 12.6v.
Old May 12, 2013 | 12:12 PM
JoanieB's Avatar
JoanieB
Water in the gas maybe, if it's been sitting or not used much?
Old May 12, 2013 | 01:29 PM
tbearmini's Avatar
tbearmini
Thought about that but I filled up right after I bought it (have only driven it about 100 miles because the tires are toast).
Old May 12, 2013 | 05:32 PM
ZippyNH's Avatar
ZippyNH
A loose nut where it connects to tge car CAN cause your issue....so make sure the terminals are tight, and check the ground under the hood.
Old May 12, 2013 | 05:54 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
ZippyNH is right about checking your ground connections and making sure the terminals and battery posts are clean and bright. Also, not connected with stalling but are you sure you bled the coolant system completely? It's EZ to get trapped air in the system.
Old May 12, 2013 | 06:51 PM
tbearmini's Avatar
tbearmini
I opened up the bleed screw and heat on high and filled it until coolant came out the screw. However, I have had to add some water to the reservoir this afternoon.
Terminals look like new. I'll have to look for the grounds and check them. Just strange that I drove the car 90 miles home through the north Georgia mountains and things were fine.
Old May 12, 2013 | 09:37 PM
minsanity's Avatar
minsanity
Not connected to cut out, but fan cycling on when engine off: Check the health of your low speed fan & +1 on the coolant bleeding.
Old May 13, 2013 | 05:04 AM
tbearmini's Avatar
tbearmini
When I bled the coolant, I found the bleed screw up front near the radiator but couldn't find the second one mentioned in some of the articles. It looks like the car has some aftermarket hoses so maybe they got rid of it.
I think I read the main ground is near the passenger motor mount? I will check that tonight.
Old May 13, 2013 | 07:11 PM
tbearmini's Avatar
tbearmini
Checked the grounds and they were fine. Changed the fuel filter tonight. We'll see what happens. Maybe the throttle body needs cleaning.
Old May 15, 2013 | 05:49 AM
tbearmini's Avatar
tbearmini
Cleaned the throttle body - it was pretty gunked up. So much that I threw a code from all the cleaner I used. Chugged for awhile but took out for a spin and now the idle is very smooth. Hopefully that was my issue.
09R56
Nov 16, 2022 10:49 AM
dchang0
Aug 10, 2015 03:37 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
