Navigation & Audio Question about Nav Update
Old May 11, 2013 | 08:47 AM
Vassago68's Avatar
Vassago68
I'm in the Military stationed overseas and just took delivery of my new Mini. It comes with US Maps since it's US Spec, and since I am here for a year more, I went ahead and ordered the Euro USB maps.
My question is this, in the manual it says it could take up to a few hours to update, that you should start the update and let it update while you are driving.
I'm hardly out for long road trips here. Normally I go to and from work, and a few errands here and there. Nothing that would require more than a 30 min drive one way.
Should I just start the update on a weekend and turn the car on every now and then to charge the battery? Has anyone else gone through this process?
Old May 14, 2013 | 10:58 AM
Blind Dog Daddy
I would suggest keeping the engine running during the entire process or connect a battery charger to the battery to maintain a constant voltage level. Low voltage levels and spikes created by starting car may interrupt your map update process or cause it to fail in some way.
Do you have a garage? If so, the battery charger method would be the way to go, you could safely let it update while doing other things.
Old May 14, 2013 | 11:59 PM
cactusbob's Avatar
cactusbob
It took hours on mine, in retrospect I should have just gone for a drive somewhere. It virtually drained my battery whilst doing it.
Old May 18, 2013 | 09:04 PM
2kaccordocoupe's Avatar
2kaccordocoupe
You don't have to keep driving while it updates. Start the update and then drive normally, if you stop so does the update. Then when you start driving again it continues where it left off. Takes approx 45 mins to update via a high speed USB stick.
OYWHATNEXT
Navigation and Audio
12
Jun 14, 2016 09:36 AM
kevinminict
Jun 3, 2016 01:31 PM
Dec 23, 2015 10:36 AM
dscott90000
Aug 23, 2015 08:21 PM
