Another Rotiform question....
Old May 8, 2013 | 11:23 AM
Rohr'n Mini's Avatar
Rohr'n Mini
I tried searching, but came up with nothing on this. I am looking at the 30 offset 17 x 8 Nue wheel for my 2011 R56 S. Would I be able to run a 215/40/17 tire without rubbing? Anyone have experience with this? I am running stock suspension and may go with a mild spring drop down the road. Thanks for any help.
Old May 8, 2013 | 11:39 AM
Creeve's Avatar
Creeve
It'll probably rub. Here is an example:
Old May 8, 2013 | 12:00 PM
Go_Fast's Avatar
Go_Fast
lol
That's my car.
I have 215/40/17 Yokohama S-Drives on those 17 x 8 ET30 BLQs. At stock height it does not rub. I have NM springs, Koni Yellows, H-Sport Rear Camber Links, and a H-Sport Sway Bar being delivered on Friday. After it is all installed, I'll let you know if I actually got a 30mm drop and if I'm rubbing.
Old May 8, 2013 | 12:54 PM
Rohr'n Mini
Thank you for the information. So it looks like it is pretty flush and does not rub while stock.
Go_Fast keep me updated after you have everything installed!
Old May 8, 2013 | 12:57 PM
Creeve's Avatar
Creeve
Originally Posted by Go_Fast
lol
That's my car.
Have you had 4 people it the car yet?
That is well past flush.
Old May 8, 2013 | 01:03 PM
Go_Fast's Avatar
Go_Fast
3 adults, no rubbing. I never have 4 people in the car and even 3 is rare.
Old May 8, 2013 | 01:05 PM
Rohr'n Mini
It looked flush to me. Maybe my eyesight is not as good as it used to be. I do see some poke now that I look again...
Old May 8, 2013 | 01:17 PM
Go_Fast's Avatar
Go_Fast
A little poke but not a silly amount. It will change after all the parts are installed.
Currently: front wheel gap: 65mm (2.5"), rear: 70mm (2.65"?)
Old May 8, 2013 | 01:32 PM
Creeve's Avatar
Creeve
A little but not silly. It will change after all the parts are installed.
Oh that actually makes sense then. There literally isn't enough up travel in the stock suspension for the tires to rub.
Old May 25, 2013 | 07:13 AM
Mjimport's Avatar
Mjimport
I have an r53 with exact wheel/tire setup and no rubbing, im on Tein springs.
I know r56 is a little different for clearances.
Piolk
Feb 13, 2016 11:47 AM
Piolk
Mar 24, 2015 09:01 PM
Mjimport
Oct 22, 2013 01:59 PM
ParrishBlue
Nov 9, 2006 08:59 AM
