R50/53 Service Mode Bolts
Old May 8, 2013 | 07:53 AM
ieandro's Avatar
ieandro
Service Mode Bolts
Will be doing some work this weekend and was going down to the hardware store to pick up a pair of the m8 x 100 bolts that everyone says to use to get it in service mode.
Does the bolts itself have to be 100 in length? Would it make more room for a m8 x 120 or even 140? The longest bolt they have is a 180.
Old May 8, 2013 | 09:23 AM
BlwnAway's Avatar
BlwnAway
The longer the better, since your using them to hold the core support while you disconnect things, the more room, the easier it is.
I've always just used the bumper bolts though, they're long enough IMO.
Old May 8, 2013 | 10:03 AM
Blayne's Avatar
Blayne
Still kinds new to the Mini scene. What is the service mode?
Old May 8, 2013 | 12:06 PM
AlexQS's Avatar
AlexQS
Hi Blane, Welcome to the new scene!
Check out the Stickies at the top of this r53 forum. Basically it's telescoping the front bumper out away from the engine to give you more room to work on it.
Cheers
AlexQS
Old May 8, 2013 | 07:03 PM
ieandro's Avatar
ieandro
Thanks errrbody!
I ordered the M8 x 1.25 x 180 bolts. Hopefully they will make it even easier.
Old May 8, 2013 | 08:07 PM
ZippyNH's Avatar
ZippyNH
https://www.northamericanmotoring.co...front-end.html
Here is the info!
Service mode allows you about 4 – 5 inches of space in front of the engine block (and behind the radiator) to enable access to that area. In my case, I needed to have better access to the area where the dipstick guide tube enters the oil pan. I needed to remove the guide tube and take out the broken dipstick stuck inside.
So herewith is my tutorial on how to take off the bumper, bumper carrier, and put the Mini into “service mode”. I put this together by consolidating everything I could find on the various US and UK Mini forums. There were several nice write-ups I found that listed the steps - but none had pictures. In addition, most of them were obviously written by folks who do this all the time, and already know where everything is, etc., whereas it took me a bit of time and patience to locate all of the necessary bolts, etc. I felt that a very basic step-by-step guide, with pictures, would be helpful. I should note that this particular tutorial does not involve removing the wheels - I found that I could access the wheel wells just fine by turning the wheel as far it is would go on each side.
Old Mar 24, 2014 | 09:45 AM
mokiach's Avatar
mokiach
Here are some instructions with photos of using the bolts to slide the radiator out of the way for working room.
http://www.pelicanparts.com/techarti...ant_Change.htm
09R56
Nov 16, 2022 10:49 AM
MORENOJM
Sep 20, 2016 08:13 PM
JPMontes3
Aug 23, 2015 01:26 AM
xpunisherx
Aug 10, 2015 10:50 PM
tippin
Aug 5, 2015 08:43 AM
