R56 Buzzing, humming noise from Wastegate vane when turning off
Old May 7, 2013 | 04:31 PM
tjkenny15's Avatar
tjkenny15
Hi all,
So I've had this issue recently. When I turn my car off, no matter how long it's been running, it makes this buzzing/humming noise for a couple seconds. I took the intake box off and determined the noise is coming from the back side of the engine.
From reading other posts on other websites, it sounds like it could be a vane some how connected to the wastegate. Has anyone else ever had an issue like this? I don't have any check engine lights. I've noticed a slight lack of boost build up though. Hardly unnoticeable.
Here is a video I found of the exact noise issue I've got.
You Tube
"> You Tube
" type="application/x-shockwave-flash" width="425" height="350">
Thoughts about how to fix this? Has anyone had this fixed? Cost? Thank you!
-Tim
Old Jun 8, 2014 | 07:18 PM
maximoose's Avatar
maximoose
Tim, have you gotten a response from anyone on this, were you able to fix? I'm suffering from same issue. If it's the wastegate, they i'm guessing it would require a whole turbo replacement. If it's the actuator, then that should be cheaper.
Old Jun 8, 2014 | 07:26 PM
cerenkov's Avatar
cerenkov
That's the kazoo sound,
check out this thread:
https://www.northamericanmotoring.co...ering-off.html
Old Jun 9, 2014 | 05:50 AM
tjkenny15's Avatar
tjkenny15
I actually never had it fixed. The car blew up on me when driving on i95 just cruising at about 70mph. An exhaust valve broke and I ended up just selling the car. I'm done with MINIs.
Good luck with your car. It is the kazoo sound that cerenkov speaks of. It shouldn't be too expensive of a repair if you fix it yourself. The valve breaking is completely un-related btw.
rikaro
Aug 7, 2021 02:33 PM
maestro39
Oct 27, 2015 02:38 PM
coachvminis
Aug 25, 2015 06:58 AM
patrioticmini
Aug 20, 2015 10:54 AM
yashmack
Aug 15, 2015 03:11 PM
