R50/53 Prosport evo series boost gauge HELP!
Old May 7, 2013 | 04:25 PM
R53minime's Avatar
R53minime
Can anyone help me hook this up what do you have the wires hooked into mine won't turn off
Old May 7, 2013 | 04:42 PM
Braminator's Avatar
Braminator
How do you have it powered? What colored wires are you using for accessory power?
Old May 7, 2013 | 04:46 PM
R53minime's Avatar
R53minime
I was using the cigarette lighter fuse I am using one of those piggy backs
Old May 7, 2013 | 04:51 PM
R53minime's Avatar
R53minime
And I tried multiple things for the other ones but it just stayed on
Old May 7, 2013 | 05:29 PM
Braminator's Avatar
Braminator
Is your orange wire hooked up to the headlight switch?
Old May 7, 2013 | 05:30 PM
R53minime's Avatar
R53minime
Which one is the headlight switch? It was kinda hard for me to read the fuse's
Old May 7, 2013 | 05:40 PM
Braminator's Avatar
Braminator
Did you use the fuse panel in the car or engine bay?
Old May 7, 2013 | 05:46 PM
Braminator's Avatar
Braminator
The switch its F8 in the inside fuse box.
Old May 7, 2013 | 07:18 PM
R53minime's Avatar
R53minime
I did not try that fuse I will tommorow braminator do you know a good engine accessory power?
Old May 8, 2013 | 07:51 PM
R53minime's Avatar
R53minime
This is not making any sense to me at all when I test fuse f8 with car off with my test light I get power and a few other fuses but when I turn the acc. On nothing is getting power my lighter fuse I can't get to light up at all with my tester I can't figure this out
Old May 9, 2013 | 05:05 PM
R53minime's Avatar
R53minime
Finally got it thanks for the help
Old May 9, 2013 | 06:16 PM
Braminator's Avatar
Braminator
Glad to hear it. How did you finally fix it?
Old May 9, 2013 | 06:19 PM
R53minime's Avatar
R53minime
I used the grey wire that goes to the tack, a constants 12v from the obd plug and a wire coming from the steering wheel for the switch
Old May 9, 2013 | 07:04 PM
Braminator's Avatar
Braminator
Well I am glad you worked it out. Sorry I could not help you more.
PsychoRallye
21
Feb 17, 2019 06:08 AM
dinomaniac
Sep 18, 2018 04:19 AM
molala
Oct 2, 2015 01:53 PM
gzaos
Sep 14, 2015 04:21 AM
Sep 1, 2015 04:39 PM
