Pressures on Falkens
Old May 7, 2013 | 06:25 AM
Speedy/Speedy's Avatar
Speedy/Speedy
I have a '03 Mini S that now has Falken (non RF) ZIEX ZE-912 195/55/R16 87V tires. What are the best tire pressures? Thanks
Old May 7, 2013 | 08:43 AM
Braminator's Avatar
Braminator
36-38 psi IMO. What does your door jamb say?
Old May 7, 2013 | 08:55 AM
Speedy/Speedy
Pressures
My wife is off with the Mini so I can't check just now. But, regardless, the door jamb pressures are for the original run-flats. I'm imagining that those were of a different category than the Falkens and so the recommended pressures would not apply. Agree?
Thanks.
Old May 7, 2013 | 09:08 AM
Braminator's Avatar
Braminator
I agree, but the door jamb info is a good place to start. I run 38 on my NON runflats.
Old May 8, 2013 | 08:27 PM
afadeev's Avatar
afadeev
Thanks.
Almost.
My '08 Mini manual recommends tire pressures between 33-38 (same front/back), depending on load (higher load -> higher recommended tire pressure). Same recommendation applies to regular and RFT tires.
On my MCS, pressures right below 32 psi trip the annoying TPMS warning lights. Mid/low 40 psi (44 in my case) is usually the maximum tire pressure printed on your sidewall. So that is your operating range.
I usually pump my real tires (i.e.: non-run-flop) up to 35 psi cold for the street.
Then bleed the air out to ~36/38psi front/rear hot, on track, as needed.
YMMV,
a
bahman
Feb 14, 2016 10:29 AM
Oct 1, 2015 12:13 PM
eliseo1981
Sep 30, 2015 07:57 PM
Emnotek
Sep 29, 2015 07:37 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
