R56 fan staying on after auxiliary water pump replaced
Hi guys, finally got a chance to have the aux water pump replaced under warranty.
Got the car back few hours later, all seemed well. Popped the hood to check on the work and noticed they overfilled coolant. Went back next day told them to check level and also cause I couldn't hear the auxiliary pump running at shutdown.
They came back after an hour and apologised that it might have been air trapped and they bleeded it.
Went home and noticed fan just stays on from the moment I start the car.
It's mainly on low speed but sometimes creeps into high.
My obd scanner shows normal range temperature when running going from 95 degrees to 104/103 celsius.
Can anyone tell me where the fuse or relay is located for the auxiliary water pump. I can't seem to find it.
Do you think the thermostat temperature sensor is giving wrong readings
Also what is the chance that the Mini dealer replaced the coolant pipe that goes to the turbo from the aux pump?
What I notice is my fan will almost always stay on for a least a few moments and the turbo auxillary pump runs for a good while longer lightly humming away.... I am AOK with it all!
I live in Houston, Texas, hotter than ... Both water pumps have been replaced on my 2008 MCS. When I get home from work, pull in the garage, turn the ignition off and get out, my fan will come on high speed for a few minutes and then shuts off. This is after 1 hour of bumper to bumper traffic. This occurs with or without using the a/c on my journey.
About a week after my aux water pump was replaced, my thermostat went. Not that it's related...
I've even noticed sometimes now that the fan stays on for a bit, but only once in a while. I'm crazy about checking coolant levels and haven't noticed anything wrong.
It is odd that the fan comes on as soon as you start the car. Generally the fan doesn't come on until the operating temperature tells it to.
Did the fan come on in that week between the aux water pump replacement and the thermostat replacement? Probably so sense you took it in a week later.
well i took it to the shop and i see the coolant is all the way to the top and ok ill do that but that check engine light does it have to do with the oil?
I know there is an oil can that lights up. Anytime a check engine light comes on check the oil first. Not doing so can lead to much more expensive problems.
The message noted above with the yellow check engine has only happened once to me while vacationing in South Padre. I pulled over, added oil and the light was gone and I have never seen that message again.
Obviously their charges were ridiculous so I just bought the part and I am going to fit it tomorrow.
Could you help me out with info from the two pipes that come out from the firewall. Looking from the front you have one on left and one on right.
I didn't take note which port they plug into the housing.
Any chance you could post a pic. Thanks
I have yet to have my aux water pump changed from the recall on it, but am planning on doing it soon. Does anyone know if they change the coolant when the aux pump is changed or just top it back up.
They completely replace it with the bmw blue coolant.
gmonde
Sep 8, 2015 06:37 AM
