R56 Need help with tire pressures falken 912's
Old May 1, 2013 | 12:51 PM
korre07's Avatar
korre07
ok so i just called to order a set of falken 912's 205/40-17 for my '11 cooper s. the guy told me that in order for those tires to hold the weight of the car i would have to run them at 41 psi. stock is 35. would it be safe to cut the difference and run them at 37-38 psi? i know quite a few people who run this tire at the factory 35 psi and have no problems. any suggestions?
Old May 1, 2013 | 01:23 PM
Velocityvic's Avatar
Velocityvic
My 2008 MCS says 38psi on the door jam using the 205/45/17 runflats. Are you ordering from or checked with tirerack.com?
Old May 1, 2013 | 02:42 PM
cristo's Avatar
cristo
Alliance Member
Tirerack doesn't carry Falken.
The Falken ZE-912 in 205/40/17 has a load range rating of 84 (XL rather than regular)
so it's adequate for a Cooper S (regular load range 205/45/17 has same rating of 84).
I would run them at 38 psi just like the stock tire recommendation.
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
