Suspension R53 Rear Shocks on rear R56?
Old Apr 29, 2013 | 03:56 PM
NintenTom's Avatar
NintenTom
Quick question. Is swapping the R53 rear shocks to a a R56 possible if I purchase a pair of those adapters that are used for some shocks like the Koni yellows?
Old Apr 30, 2013 | 09:27 AM
THE ITCH's Avatar
THE ITCH
NintenTom
The quick answer is yes they will work with the adapter. The longer answer is that the R56 shocks that have the adapter as part of the shock body is being supported by the trailing arm taking the load off the shock bolt. If you use the R53 shocks with the adapter the load is only supported by the shock bolt.
Steve
Old Apr 30, 2013 | 01:35 PM
NintenTom's Avatar
NintenTom
Originally Posted by THE ITCH
NintenTom
Steve
Thanks for clearing that up for me
emulajavi
Dec 24, 2018 09:15 AM
Emnotek
Aug 13, 2015 05:47 PM
messyjesse96
Aug 12, 2015 05:51 AM
tag1260
Aug 5, 2015 04:27 AM
