R50/53 What is this?
Old Apr 26, 2013 | 12:35 PM
Skipnstones's Avatar
Skipnstones
What is this?
I was checking the oil today and noticed this. A look on realOEM shows it to be a rubber mount for the engine.
What is the oil from? I check my oil regularly and upon seeing this I looked everywhere and cannot find any leaks. Are these things filled with oil? Has mine failed? Or am I in the wrong church and wrong pew?
Any help/advice is appreciated.
Thanks.
BTW, it is a 2006 MCS.
Walter
Old Apr 26, 2013 | 12:41 PM
Mr Moe's Avatar
Mr Moe
Engine mounts. Just had mine replaced recently.
https://www.northamericanmotoring.co...ine-mount.html
Old Apr 26, 2013 | 01:41 PM
Yep engine mounts leak, they are filled with an oil.
Clean up the oil residue on the body best you can and replace the mount:
Here is the diagram:
#3 on the diagram.
Here is the parts:
http://www.ecstuning.com/Search/22116778610/
Old Apr 26, 2013 | 02:04 PM
xsmini's Avatar
xsmini
^ Do the 03's have an oil filled engine mount? They look completely different, and I didn't think they did, but I noticed oil around mine the other day.
Nik
Old Apr 26, 2013 | 02:27 PM
Here is the diagram for the older one.
Here is the - 12/2003 "Justa " Cooper
http://www.ecstuning.com/Search/22116759732/ES41663/
Here is the - 12/2003 Cooper S
http://www.ecstuning.com/Search/22116760448/ES41669/
The one above is for the 12/2003 - ALL
They have a little strap and look different. Where is the oil coming from, can you see?
Old Apr 26, 2013 | 02:40 PM
Miniman s's Avatar
Miniman s
Yes the older style mount is also fluid filled.
Old Apr 26, 2013 | 03:11 PM
DAVESTER's Avatar
DAVESTER
Use rubbing alcohol to clean it up...
Old Apr 26, 2013 | 04:33 PM
xsmini's Avatar
xsmini
Oil is right at the bottom of the unit, think its the 12/2003 S one. No oil anywhere else. I had never heard of them leaking (unlike the newer ones) so I guess I assumed they didn't have oil in them. Looks like I'll be ordering one.
Thanks,
Nik
