R56 LCI tail lights fitted in pre facelift but with check lights
Old Apr 23, 2013 | 04:34 PM
titish's Avatar
titish
I did the wiring and all is well the lights are on and working perfectly but there is a check light in my dash regarding my lights...what to do..? Any tutorials
Old Apr 26, 2013 | 10:29 AM
solskjaer1999's Avatar
solskjaer1999
Did you disconnect the battery before the install?
Old Apr 26, 2013 | 11:46 AM
titish's Avatar
titish
No
Old Apr 26, 2013 | 12:24 PM
solskjaer1999
That might have caused the issue.
Old Apr 26, 2013 | 01:13 PM
rkw's Avatar
rkw
Very unlikely. There is little (if anything) electrically happening at the taillights when nothing is turned on.
What did you do for wiring the running lights? If you wired them only to the LEDs, your car is expecting regular bulbs there.
Old Apr 26, 2013 | 01:24 PM
titish's Avatar
titish
I wired them to function like a real lci
Old Apr 26, 2013 | 01:32 PM
strobeyprobey's Avatar
strobeyprobey
The FRM will need to be coded for the change, however there is a possibility you will need to update the FRM2 to FRM3 and/or the software revision on the FRM will need to updated to support the retrofit. I haven't seen what specific codes or changes are necessary for this change. It maybe just as simple as disabling the warm and cold bulb checks on the rear parking/running lights.
Old Apr 26, 2013 | 01:56 PM
rkw's Avatar
rkw
As a crude workaround, you could try a load resistor across the running lights circuit (like people do when they replace a standard bulb with an aftermarket LED bulb).
Old Jul 17, 2013 | 12:59 PM
6thGear's Avatar
6thGear
^ yeah, a load resistor might work. You basically have to fool the car's ECU into thinking that the rear bulbs are not blown. LCI tails have LEDs which dont draw as much current as filiment bulbs and the ECU thinks the bulbs have gone bad.
Old Aug 22, 2013 | 02:04 AM
Ratonn's Avatar
Ratonn
I got myself a pair of the lci rear lights on ebay for my 07 mcs. It was kind of an impulsive purchase, but nonetheless I want to at least give the installation a go... Are there any tutorials or how tos?
Cheers
Old Aug 22, 2013 | 02:09 AM
Ratonn's Avatar
Ratonn
Hi fellow mini lovers,
Cheers
Old Oct 31, 2013 | 01:01 PM
Imraan Gassiep's Avatar
Imraan Gassiep
Looking for this too please
Old Jan 21, 2015 | 06:35 AM
Jose Antonio Romero's Avatar
Jose Antonio Romero
Hi there, I'm interested in doing that as well for an R55 Clubman, do you know how to do it?
Old Feb 9, 2015 | 01:27 PM
Jose Antonio Romero
Hi titish, how did you do the wiring? I bought a pair of tails from an LCI Clubman and I found the connector totally different! I would appreciate any help given. Thanks!
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
