R50/53 buying an r53 - what to look for
Hi. I'm looking in to buying a 2006 R53 hardtop. After some searching I've come across:
1. mushrooming
2. door sill rust
3. power steering pump/fan
4. water pump leakage
5. oil pan leakage
Are there any other issues I should be aware of / look for?
Thanks in advance!
1. mushrooming
2. door sill rust
5. oil pan leakage
Thanks in advance!
Listen to the supercharger and make sure there are no knocks or rattling.
Check the serpentine belt for ware.
Check for crank sensor o ring is not leaking oil.
Check valve cover is not leaking oil.
Check the coil on the contacts for corrosion especially on #3
Check the coolant reservoir for leaks and if it is mixing with oil.
Check the oil for coolant mixing with the oil.
I would do a compression test if at all possible.
Maybe you can take it to a Dealer or MINI specialist to get a once over done.
Get all possible service records.
This is all things I would do.
trw92a
Aug 26, 2015 01:47 PM
