R50/53 buying an r53 - what to look for
Old Apr 23, 2013 | 12:54 PM
toyopet's Avatar
toyopet
Hi. I'm looking in to buying a 2006 R53 hardtop. After some searching I've come across:
1. mushrooming
2. door sill rust
3. power steering pump/fan
4. water pump leakage
5. oil pan leakage
Are there any other issues I should be aware of / look for?
Thanks in advance!
Old Apr 23, 2013 | 01:03 PM
Braminator's Avatar
Braminator
Listen to the supercharger and make sure there are no knocks or rattling.
Check the serpentine belt for ware.
Check for crank sensor o ring is not leaking oil.
Check valve cover is not leaking oil.
Check the coil on the contacts for corrosion especially on #3
Check the coolant reservoir for leaks and if it is mixing with oil.
Check the oil for coolant mixing with the oil.
I would do a compression test if at all possible.
Maybe you can take it to a Dealer or MINI specialist to get a once over done.
Get all possible service records.
This is all things I would do.
Old Apr 23, 2013 | 06:57 PM
toyopet's Avatar
toyopet
Thanks for the reply!
PM sent.
Old Apr 24, 2013 | 05:25 AM
buzzsaw's Avatar
buzzsaw
Check for leaking thermostat gasket and check suspension bushings.
Old Apr 24, 2013 | 06:25 AM
fridayxiii's Avatar
fridayxiii
In addition to what the others posted, here's a link to the R53 buyer's guide on Motoring File: guide
+1 to having a pre-purchase inspection done as Bram mentioned.
caiken
Aug 27, 2015 06:55 AM
trw92a
Aug 26, 2015 01:47 PM
Pacman2131
Aug 24, 2015 01:54 PM
elightbo
Aug 17, 2015 01:50 PM
