Drivetrain 2006 Mini with CVT no power from 25 to 45 mph help!
Old Apr 22, 2013 | 09:23 AM
Novice Mini 2006's Avatar
Novice Mini 2006
I have just purchased a 2006 Mini with the CVT transmission. We love the car but are having apparent transmission issues. the mini starts from a stop ok then @25 mph it seems to up shift past several gear ranges, the tach drops to around 100-1200 the car very slowly accelerates if not going up hill to about 45-50 then runs better. Also Fuse F4 in the engine compartment is blown and instantly blows if new fuse is installed. Any thoughts would be appreciated. Update 6PM I have cleaned leakage detector plugs and rechecked DTC codes. codes P1611 and P2401 still there. My code reader can erase codes but it does not clear these.
04/23/2013 update short found in CVT. removing the plug from CVT assembly stopped the short. also the gear selector light works normally with plug detached. However still throws code 1611 and made no difference in driving. Also found plug on fan underneath motor was not connected.
Last edited by Novice Mini 2006; Apr 23, 2013 at 11:13 AM. Reason: additional info
Old Apr 22, 2013 | 10:03 AM
OVREZY's Avatar
OVREZY
Have you tried running in sport mode -- see if it does the same thing
Old Apr 22, 2013 | 11:16 AM
Braminator's Avatar
Braminator
Fuse F4 15A Tank Leakage diagnosis pump. Do you have a check engine light on? I would check all the pins to see that is connected properly.
Old Apr 22, 2013 | 12:38 PM
Novice Mini 2006
I have tried to switch from drive to right and change gears manually if that is what you mean. it does not change.
Old Apr 22, 2013 | 12:50 PM
Novice Mini 2006
The sport mode never displays in the gear indicator only"EP" which I think is a failure code.
Old Apr 22, 2013 | 01:13 PM
nowhereman's Avatar
nowhereman
one thing to note is that a CVT doesnt have actual gears in the normal sense. so it should never "shift"
however i have heard of the CVTs on early MINIs being very hit or miss which is why our MCS has the stick.
Old Apr 22, 2013 | 01:26 PM
KinetechMW's Avatar
KinetechMW
Old Apr 22, 2013 | 04:39 PM
Novice Mini 2006
I have read the DTC codes. P1611 and P2401. I did check and clean the leak detector plug and connectors no change still throws the codes and runs the same. The F4 fuse in the engine compartment blows instantly if changed. The red and white wire on plug located in lower left side of fuse box in engine compartment is shorted to ground.
Old Apr 22, 2013 | 05:43 PM
ZippyNH's Avatar
ZippyNH
P1611 Serial Communicating Link Transmission Control Module
P2401 Evaporative emission leak detection pump, control - circuit low
Can you bring the car back to the seller?
The fact you have a fuse that blows instantly...and a shorted wire sounds like this fix could get interesting....wiring and or computer/control modules....
Then add the typical CVT issues.........
Old Apr 22, 2013 | 06:13 PM
KinetechMW's Avatar
KinetechMW
I gotta say, I agree, bring it back to whomever you purchased or get it to your local shop ASAP. How long has it been doing this? if its a short you should have noticed something almost from day one.
Old Apr 23, 2013 | 02:58 PM
Novice Mini 2006
I have found several plugs disconnected, one on the evap motor and also on the cooling fan for the steering. I cleaned connectors and plugged back in. Also have a blown fuse "F4" in engine compartment fuse box. found red /white wire had short. Traced to large connector on front of CVT disconnected this plug and short cleared. Replaced fuse and did not blow also Shift indicator now works normally. However still shifts the same. Do you have any suggestions?
SosoMINI
Nov 22, 2015 03:17 PM
xpunisherx
Aug 10, 2015 10:50 PM
sungjk
Aug 5, 2015 08:23 PM
rphox2003
Aug 5, 2015 11:34 AM
