15" rims on an S?
Old Apr 22, 2013 | 05:49 AM
tommyspitfire's Avatar
tommyspitfire
15" rims on an S?
I recently replaced my '03 Cooper with an '09 S. Awhile back I took the 15" 7 hole stock rims off the 03 and replaced them with 17" Focals that are now on the S. I tried selling the stock rims on Craigslist and a garage sale with no success. So now I'm thinking of keeping the stock rims and using them for snow tires in winter. The question I'm wondering is there a problem with putting the smaller rims on an S? I know there's no problem with the bolt pattern, but is the size of the wheel a problem because I noticed you can't build a Cooper S with a wheel smaller than 16".
Old Apr 22, 2013 | 07:21 AM
yetti96's Avatar
yetti96
The 15s will not work on the R56 S you now have. The brakes are now bigger and the wheel will most likely not clear the caliper.
You can jack the car up and just mount the wheel without a tire and see, but I would try selling them here on NAM, tons of non-S car could run them as a winter set or Auto X set.
Old Apr 22, 2013 | 07:26 AM
tremperj's Avatar
tremperj
Some 15's can fit. I believe I have read of some folks running SSR and Slipstreams in a 15" size. But those Imola Holies are not gonna fit your R56, sorry. Sad, its a great looking wheel.
Old May 18, 2013 | 01:00 PM
MINI #1's Avatar
MINI #1
You will rub the ground over the potholes and speed bumps w/ 15s
Old May 18, 2013 | 01:07 PM
ZippyNH's Avatar
ZippyNH
Nope...with properly sized tires, the OUTSIDE DIAMETER IS THE SAME with ALL tire/rim combo's.
and 15's work on a gen1 s, no bbk, but will not work on a gen2...the gen2 s brakes are the same calipers/rotors as a gen1 bbk.
Old May 18, 2013 | 03:52 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
1+
Stock 15x5.5" wheels are fine for early R50 and R53 MINIs with standard brakes.
R56 brake calipers only allow for 16" wheels and larger.
Aftermarket 15" wheel might fit if the spoke design allows for enough clearance, at least 3mm is best.
The MINI will work with 15" wheels and even with a lowered suspension. As stated, as long as you make the tire fit the wheel and have a tire diameter of about 24.3" it will work like a stock fitment. You can even run the tire size that is slightly less than 24" and it will still work on the street but with less clearance.
I have run tires down to about 23" tire diameter on the street with 15" wheels and it is fine, just be careful.
Old May 18, 2013 | 08:17 PM
MINI #1's Avatar
MINI #1
You guys live in the nice part of the country ...not in Jersey City...15s made the R52 rub...the potholes, speed bumps, & when you have 8 different patches that are uneven pavement...while 17s looked good...those rims bent under the same conditions...I have had six minis and I find that the 16s w/ 205-50-16 non-runflats are the best all around combination for my area.
Old May 18, 2013 | 11:52 PM
minsanity's Avatar
minsanity
On Holies/15s + R56 Brakes, ask Professor & MartijnGizmo over at m|u:
Martijn's on Holies:
Professor's:
Old May 19, 2013 | 04:50 AM
MINI #1's Avatar
MINI #1
...that setup would not work where I live.
Old May 19, 2013 | 05:06 AM
00m.u037's Avatar
00m.u037
I just installed my 15' inch wheels and left the suspension as is because of the horrible roads where I live. I would love to lower it but I cannot risk it until I get an x brace or an oil pan protector.
Old May 19, 2013 | 10:29 AM
tremperj's Avatar
tremperj
Here's a set of 15's for sale that will clear the R56 brakes.
EDIT:
Looks like NAM doesnt care for linking to other Mini sites. Check Motoring Alliance.
Old May 19, 2013 | 01:47 PM
minihune's Avatar
minihune
If you use tirerack.com's upgrade garage and set it for 2012 Coupe base Cooper you can see 15" wheels that might fit the R56.
see
http://www.tirerack.com/wheels/resul...rSpecial=false
Check with alex@Tirerack.com to be sure.
Old May 19, 2013 | 02:09 PM
mini coop's Avatar
mini coop
What you are saying is that any size wheel/tire combination won't work where you live - "if the car is lowered". Because as previously stated, the diameter and circumference stays the same regardless of wheel size - 15 inch to 18 inch. This specification does not change if you are looking to maintain oem standards and speedometer accuracy. Rough roads are tough on 17 and 18 inch wheels/tires as there is not much side wall to protect either. The 15 inch wheels would actually be the best for you as the ride is softer due to more sidewall and the sidewall height protects your wheel from curb rash and pothole depth damage.
Old May 19, 2013 | 02:25 PM
minihune's Avatar
minihune
I think he may mean-
205/50-16 is the sweet spot tire size for his area giving enough handling balanced with a bearable ride.
15" wheels with 195/60-15 tires will also give a pretty decent balance (performance vs comfort) but maybe a little less grip at the limit depending on which tire. The 195/60-15 tire will offer less rolling resistance and slightly better mpg.
Old Oct 8, 2023 | 08:27 AM
dustyneil13's Avatar
dustyneil13
I have 15 inch 4 x 100 rins on my r56 2012 mini Cooper right now
This is my R56 base model I am putting the s model spoiler on :-) I'm glad it will fit
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
luisfv56
Nov 16, 2015 01:55 PM
malibujoey
Nov 9, 2015 08:22 PM
Winston46
Nov 9, 2015 06:18 AM
