R52 since we are on the topic of newb...
Old Apr 16, 2013 | 05:28 PM
txmedic1's Avatar
txmedic1
i've already got one newb thread going, but i have so many more questions!!!!!
My R52 (non xenon) are the worse i've ever seen. I've tried polishing the lenses (slight haze, but not bad) and i still cant see. i've upgraded to a "whiter" bulb, still no help.
Anyone here running aftermarket HID's on non xenon buckets?
I have HID's on my Silverado, and absolutely love them. My only concern is where to mount the ballasts.
I hate my tail lights also. i want amber turn signals. will any other stock tail light with amber turn signals fit my R52 convertible?
and last....rear fog light. i see the kit, but what about a switch for the stock switch cluster where the locks and window switches are?
Old Apr 18, 2013 | 08:27 AM
Max7's Avatar
Max7
Here is the rear fog light:
http://www.ecstuning.com/Search/6324...aign=postreply
It might need wiring you will have to check yourself by removing the cap and fishing for a bundle of wires. They are most likely tucked upwards, but if not you will need this aswell.
http://www.ecstuning.com/Search/6312...aign=postreply
Depending on your car if you have the DSC switch you will need this switch panel:
http://www.ecstuning.com/Mini-2004-C...ches/ES167631/
Also here is the entire front fog light + wiring kit:
http://www.ecstuning.com/Search/6313...aign=postreply
Old Apr 18, 2013 | 12:02 PM
txmedic1's Avatar
txmedic1
Thanks Max!!!
what about running aftermarket HID's in halogen buckets?
Old Jun 9, 2013 | 07:43 AM
txmedic1's Avatar
txmedic1
Originally Posted by txmedic1
Thanks Max!!!
anyone?????
Old Jun 16, 2013 | 05:57 PM
AlexQS's Avatar
AlexQS
Thanks Max!!!
I'll be curious to know if that works well.
Wanted to say, my halogens were aimed way too low when I got my car. Not hard to adjust. It's the inner ones for height, outer ones adjust left and right (I didn't mess with those). Counter clockwise is higher, clockwise lowers (if I remember correctly)
Turn them about a 1/4 or 1/2 turn at a time. Write down how far and which direction you turned it, then go for a drive. Make note of your impressions.
I actually went to an empty parking lot at 1:00am, had some blue scotch tape and a tape measure. Positioned the car exactly 25 feet away from the building (my 90^ screen). I had some PDF instructions for what DOT says about where the light should be, etc. that's on my other computer though. Let me know if anyone wants it.
Mb460
Aug 20, 2016 10:39 PM
Ladybug-S
Oct 14, 2015 08:24 AM
Colt45Magnus
Sep 23, 2015 07:38 PM
Wertles
Sep 19, 2015 09:22 AM
Carrboroman
Cooper (non S)
Aug 28, 2015 08:13 PM
