R50/53 Foglight lens replacement
Old Apr 20, 2004 | 07:00 PM
kumquat78's Avatar
kumquat78
OK, I have a problem and a question. I have searched and haven't found anything on this. Let's just say, I am now a big fan of headlight/foglight protection on the MINI.
My foglight lens is smashed, its totally gone. All I have now is a reflector with a bulb in it. Actually, still works, just isn't pretty. I WANT IT TO BE PRETTY!!!
Is this something I can do myself, should I order the part from classic, or should I swing by Home Depot and look for some plexi-glass.
Any ideas?
Old Apr 20, 2004 | 10:07 PM
dave's Avatar
dave
pug poo picker-upper
I had a similar thing happen to my MINI foglights. In my case both lenses were cracked.
MINI doesn't sell just the lenses, but instead makes you buy the entire foglight assembly. There is a Left and a Right assembly. Also, the wiring harness changed up a bit so some model require an additional little parts kit to hook up the new assembly (my 2002 required this).
Give the Classic MINI Parts Department a call and they'll get you squared away. Be sure to mention North American Motoring and you'll get a discount. That's how I purchased my foglight parts. Even with shipping it was about $40 cheaper than what my local dealer wanted.
BTW, to get at the foglights you're going to need to undo the wheel well liner to get access to the three screws that hold the foglight in place. I also found it helpful to remove the bumpercover, but that's not necessary.
Your MINI will be pretty again! :smile:
Old Apr 21, 2004 | 07:51 AM
kumquat78's Avatar
kumquat78
Thanks, appreciate the help, will I be able to jury-rig something budget in there in the meantime?
Old Apr 21, 2004 | 08:04 AM
dave's Avatar
dave
I suppose you could get clear plastic and try to place that over the front of the foglight, after removing any of the remaining glass lens. To do that you'll need to remove the bumpercover. Mind you I'm not sure how you'd attach the clear plastic to the foglight housing.
Old Apr 21, 2004 | 08:50 AM
kumquat78's Avatar
kumquat78
Where there's a will.....
Any idea what TIS tells how to remove the bumper, and do I have to worry about airbag sensors?
Old Apr 21, 2004 | 08:52 AM
dave's Avatar
dave
It's just the bumper cover, not the bumper. There are a series of screws around the perimeter of the bumpercover.
I believe there is a fog light how-to floating around here that details the process.
Old Apr 21, 2004 | 08:59 AM
dave's Avatar
dave
Anyone know what happened to Sean Bartnik's Bumpercover Removal How-to? His site doesn't appear to be active any longer. Is it hosted somewhere else?
Old Apr 21, 2004 | 12:33 PM
H&J's Avatar
H&J
In the future, would some of that clear bra stuff work over the lenses for protection?
Old Apr 21, 2004 | 12:40 PM
kumquat78's Avatar
kumquat78
Yeah, I'm definitely gonna have to do that once I get this pretty once more
Old Apr 21, 2004 | 02:48 PM
dave's Avatar
dave
Ah Ha! I found it.
Sean Bartnik's New Site with the Bumpercover Removal Instructions
eliseo1981
Jan 28, 2021 02:45 PM
woodstudio
Mar 15, 2020 08:28 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
JPMontes3
Aug 23, 2015 01:26 AM
