R50/53 Just got my 17% installed as well as my dt bpv
Old Apr 16, 2013 | 08:28 AM
R53minime's Avatar
R53minime
1st run I forgot to turn of dsc
Old Apr 16, 2013 | 09:41 AM
Braminator's Avatar
Braminator
Very nice. Good luck with your tires.
Old Apr 16, 2013 | 09:43 AM
R53minime's Avatar
R53minime
Ya I know they are brand new I am going to try to take it easy on them
Old Apr 16, 2013 | 10:27 AM
ZippyNH's Avatar
ZippyNH
Sounds like it is time to step up and get something more sticky!!
Have fun!
Old Apr 17, 2013 | 12:01 PM
piston's Avatar
piston
Hey bram does your mcs have an lsd?
Old Apr 17, 2013 | 03:09 PM
R53minime's Avatar
R53minime
I got my pulley installed and at about 4,000 rpm I seems like it misses then picks back up also only in 4,5,6 gear any ideas?
Old Apr 17, 2013 | 05:17 PM
astroBlackMetallic_Mini's Avatar
Ya, mine does that sometimes too. Not sure at what rpm, could be around 4 or higher. Think it's lack of fuel, or, the ecu tune, or that damn ethanol in the gas.
Old Apr 17, 2013 | 08:05 PM
nicefighter80's Avatar
nicefighter80
R53minime, What else is done to your car?
Old Apr 17, 2013 | 08:30 PM
R53minime's Avatar
R53minime
It is just those 2 things the 17% and the dt bpv they are my first mods to my mini so far but I wanted to do a cam bigger injectors and a tune but was wondering if anyone has figured out why it does that
Old Apr 18, 2013 | 04:55 AM
Braminator's Avatar
Braminator
As of right now no. But when my clutch goes I will add it then.
Old Apr 18, 2013 | 07:31 AM
Helix13mini's Avatar
Helix13mini
Be sure that you both are using trusted, high-octane gas.
Old Apr 18, 2013 | 08:28 AM
R53minime's Avatar
R53minime
I use 93 what do you suggest that is trusted?
Old Apr 18, 2013 | 09:42 AM
ZippyNH's Avatar
ZippyNH
Should be fine....most retailers are honest. When you get a "bad tank" you will likely feel it. Modern fuels have a very short shelf life....then they start to degrade. Most higher volume retailers get delivery's every couple of days...so you should be fine. Just use caution in getting fuel from the tiny station, that sometimes has a GREAT price to empty their tank just prior to a delivery.
Name on the sign does not mean much...even the indepent stations often get their fuel from the SAME TRUCKS, THE SAME PIPELINES....they even buy the leftover fuel out of the name brand tanker trucks before they return for refilling...
So just just buy fuel from the places 99% of us buy fuel from!!
Just avoid that sketchy place you have noticed the fuel seems to burn to fast, or the car doesn't seem to run right from...or had to add some dry gas to or injector cleaner too...lol...think every town might have ONE or TWO kinda sketchy places!!
Old Apr 18, 2013 | 11:34 AM
Helix13mini
Any high-volume reputable brand gas station should be good.
Old Jul 3, 2013 | 08:27 AM
drewffff's Avatar
drewffff
Could you feel a difference with the dt bpv or did you do both mods at the same time?
Old Jul 3, 2013 | 08:29 AM
R53minime's Avatar
R53minime
I did them at the same time
Old Jul 3, 2013 | 11:01 AM
IQRaceworks's Avatar
IQRaceworks
When I did my DT BPV....I noticed that the boost "to-to" at mid throttle went away, it came into boost a little faster, and my MPG went down 1-2 MPG.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
