MCS 2005 CVT Rebuild
Old Apr 13, 2013 | 11:17 AM
Dvskiles's Avatar
Dvskiles
Just wanted to praise 5th Gear in Broomfield, Co for an efficient, courteous and effective diagnosis and rebuild of our 2005 MCS CVT. Symptom of failure at 94K miles was violent hard shift and, as the transmission warmed up, no gear shift control. The CVT valve body assembly was replaced and the transmission is working well. The folks at 5th Gear car also replaced the EC power steering two years earlier which works like original. We're proud of this little car and happy there is a Mini shop like 5th Gear we can rely on.
Old Apr 13, 2013 | 11:22 AM
ZippyNH's Avatar
ZippyNH
Originally Posted by Dvskiles
J........2005 MCS CVT....
Good to hear you found a good shop!!
Question.
IS it a Cooper? THAT is the car that had a CVT?
The S have a conventional ASIN made tranny with a Valve-body issue....
Old Apr 13, 2013 | 12:39 PM
Dvskiles's Avatar
Dvskiles
5th Gear cvt valve body replacement
It is the 2005 Mini Cooper S for which CVT failures are ( were ) common. There's a lot of negative words out there about this problem. A positive is there are shops like 5th Gear now who can make it whole.
Old Apr 13, 2013 | 01:01 PM
cristo's Avatar
cristo
Alliance Member
As ZippyNH said, CVT's only exist in the 1st gen non-S normally aspirated 115 hp Cooper (R50) and non-S version of the Convertible (R52).
If someone swapped one into an MCS (R53 with supercharger and 168 hp) it would not last long at all.
Old Apr 13, 2013 | 01:14 PM
ZippyNH's Avatar
ZippyNH
SORRY YOU ARE CONFUSED....
The ASIN (of Japan) tranny used in the 2005+ gen1 S is very common in VW's, toyotas and a few Audi's....very minor changes to each model.
The valve body changes are actually done as a warranty item on the VW with the same tranny....
The CVT is an entirely different beast...no Gears, NO valve body....but an electronic controller and 2 piullies shaped like a cone, and belt....submerged in oil....
The importance of the differentiation is that BASICALLY NOBODY has relibibily found a way to FIX the CVT's....
They get lucky on one....then have another one that does not work...
Most ANY transmission shop can WORK on a S tranny!!
Still Good you got it fix!! Shop suggestions are ALWAYS good!!Don't get me wrong, but it is not a $7500 issue like with a CVT! I just don't want a CVT owner to have a CVT towed in to have the shop turn them away...
http://www.motoringfile.com/mini-r50r53-buyers-guide/
2005 / One, Cooper, Cooper S
The 2005 model year MINI Coupes introduced a number of new features and advancements that addressed issues with both design and engineering of the original car. Hundreds of components were upgraded and several key drivetrain improvements were made............
Another area that problems persisted were with the One and Cooper models with the optional CVT transmission. While issues seem to be less frequent than the earlier cars, the basic design of the transmission didn’t change in ’05 and thus it would be wise to keep this in mind when shopping. Of course the newly released automatic on the Cooper S was a traditional torque converter style auto that doesn’t share any of the CVT issues. That said modern automatic transmissions aren’t always known for their long-term (100k+) reliability so keep that in mind.
Old Apr 13, 2013 | 06:05 PM
Dvskiles's Avatar
Dvskiles
2005 CVT Rebuild
This a 2005 Cooper S , 168 horsepower with a excellent rebuilt CVT : BELTS, PULLEY AND VALVE BODY ASSEMBLY. The car is a dealer demo with all the toys including a valve body CVT. Come to Denver, I'll take you for a drive bitte schon.
Old Apr 13, 2013 | 08:21 PM
minsanity's Avatar
minsanity
Dvskiles, like everyone said, the MCS has an AISIN auto tranny, not CVT. Unless one was forced in.
Old Apr 14, 2013 | 02:11 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
OP is just a tad confused on the equipment in his MINI. While his automatic 05' MCS does have a rather expensive valve body (appx $2K), it's just not a CVT.
Old Apr 14, 2013 | 01:45 PM
Aspen's Avatar
Aspen
it is a conventional automatic transmission with a valve body (tf60sn by aisin) NOT a CVT. perhaps they changed your supercharger belt and pulley/idler while they were fixing your tranny. there are no MCS's with cvts.
Old Apr 14, 2013 | 05:27 PM
Densmini's Avatar
Densmini
'Cause who in the world would want one?
mdutton11
14
Oct 26, 2015 01:47 PM
Manny_cooper
Sep 17, 2015 06:17 AM
SolCalMini
Aug 29, 2015 07:25 PM
whosurgaddy
Aug 29, 2015 09:50 AM
calebmil
Aug 7, 2015 05:54 AM
