ac inop...anyone? anyone? Bueler?? Bueler??
Old Apr 11, 2013 | 03:25 PM
nitsua's Avatar
nitsua
see Title...askes it all, anyone have an a/c inop, no compressor cycle at all...
Thanks in advance
fuse ok, connections ok
Old Apr 11, 2013 | 03:38 PM
daflake's Avatar
daflake
More information would be helpful... Have you checked the coolant pressure? Might need to be charged. Low pressure and the compressor will shutdown to keep it from being damaged.
Old Apr 11, 2013 | 03:40 PM
ZippyNH's Avatar
ZippyNH
get into a shop....most likey needs a recharge of 134A.
Can be DIY'd, BUT can also mess stuff up...you are just guessing how much oil is getting added with the DIY kits, too much can mess stuff up....as can the additives that many companies add to the kits..like moisture removers, leak stoppers, and "turbo" cool accelerators, etc.....
Old Apr 11, 2013 | 04:36 PM
avuton's Avatar
avuton
Also, not "just a recharge", someone needs to find the leak(s). Refrigeration system charging fluids don't go bad; seals and other components leak. You can have a mech recharge it, but the problem will come back as long as the leak(s) aren't fixed.
Old Apr 12, 2013 | 10:15 PM
Eric_Rowland's Avatar
Eric_Rowland
Does the clutch engage, or does it just not blow cold? In my case the low speed fan resistor died, which lead to the compressor dying. Not a terrible DIY, at about 1/4 the cost of a shop.
DutchR
Aug 8, 2011 02:47 PM
jbmdds
Aug 18, 2010 05:03 PM
wjonesiv
Jul 17, 2008 06:06 PM
