R53 jcw brake help
R53 jcw brake help
Hi would just like to ask if somebody can help me in completing this system. I have an r53 jcw caliper with carriers. Would just like to confirm if these are the things that i need.
1. Front rotors (please recommend whats the best front rotors for this one.) i think an r56 rotor can fit here.
2. Brakepads ( for daily/street use twisty roads) brakepads for r53 or r56 mcs!
3. Brake sensor ( do i need a nee one)
4. Ss lines ( is there a set where u can buy the r56 sslines in front and r53 in rear)
5.do i need bushings or whatever is that called
6. Do i need to buy any rebuild kits?
We have several rotor options that are super affordable for you
Plain face:
http://www.waymotorworks.com/wmw-joh...0-r53-r52.html
Drilled and slotted:
http://www.waymotorworks.com/wmw-dri...-cooper-s.html
You can reuse your old pad sensor as long as your light is not on.
As for lines we can put a set of our WMW ones together for $99 for you
Plain face:
We have some of the ECS Geomet Brake Rotors for the Gen 1 R50 R52 R53 JCW .
Crossdrilled / Slotted Fronts JCW
Rear
Slotted Front JCW
Rear
Our ECS Geomet Service Kits include Rotor in the same type above with sensors and Hawk HPS Pads.
For example:
Brake Lines we have ECS Exact Fit SS kits.
Production from 4/2003-
http://www.ecstuning.com/Search/002435ECSKT/ES2608378/
Production to 4/2003-
http://www.ecstuning.com/Search/002435ECSKT/ES2608944/
For the brake bushings inspect the JCW fronts, make sure they slide very easy.
Boot kits look like this:
http://www.ecstuning.com/Search/34116768189/ES59864/
Rears share the same caliper hardware as the R50 R52 R53 non JCW. Check them for wear and easy of movement.
Let me know what you want, we are here to help.
Rear
Slotted Front JCW
Rear
For example:
Hi don't mean to hijack your post but I have a similar question. I have a 2004 JCW. how can I tell if it is has JCW brakes or just R53 brakes. the front rotors are 11 in diameter. Ive attached a couple pics. thanks for your help.
R53 JCW and R56 S brake rotors are 294 mm diameter.
I think its 279mm (11 inch) for R53 S (non-JCW).
R53 JCW calipers are red.
Looks like those are regular R53 calipers and rotors.
- andy
- andy
Minibeagle -
alanzilo -
Look like the stock brakes. The JCW "Red" brakes were an upgraded option at that time.
The Stock rotor size for Gen 1 R50 r52 r53 fronts are 276x22 or about 10.86".
The JCW Rotor size for Gen 1 R50 R52 R53 fronst are 294x22 or about 11.57"
2004 MINI Cooper S (stock non JCW rotors) Front Rotor Cross drilled / slotted.
http://www.ecstuning.com/Search/341891XSGMTLRKT/
2004 MINI Cooper S Rear Cross drilled and slotted ( Same on JCW and non JCW ) 10.19" 259x10
http://www.ecstuning.com/Search/342070XSGMTLRKT/
Thanks and hope that helps.
Let me know if your need anything else.
alanzilo -
Aug 12, 2015 01:24 PM
