R50/53 Spark plugs to go with reduced pulley?
Old Apr 9, 2013 | 10:22 AM
Jaydavid's Avatar
Jaydavid
So my serpentine belt has about had it its cracked all over and i have decided to get a 15% cravenspeed reduction pulley and smaller serpentine from Outmotoring. My question is what spark plugs should I get to go along with these mods all i know i need a colder rage plug. Advice on the best plugs to get from Outmotoring would be helpful thanks!!!!
Old Apr 9, 2013 | 10:37 AM
ZippyNH's Avatar
ZippyNH
My suggestion on a brand is ngk...
As for heat range, one step cooler, which means the JCW PLUGS...not sure of the number off the top of my head, but when you look up plugs, the books will list cooper, cooper s, and cooper s with jcw....that or any competant parts person can get you "one step cooler" than the stock s plug if they know how to read the standard plug....
Old Apr 9, 2013 | 10:44 AM
Jaydavid's Avatar
Jaydavid
Ok on the outmotoring website i picked the ngk irdium IX it gave me two options standard and colder. It doesnt say what heat range or recommend what to get with the pully so i picked colder am i going the right direction i just dont want to order them then have the wrong ones im shure i could just go to autozone and get some but i figured it might better to get them specifically from a mini website instead of asking som kid at a car parts store who doesnt know anything.
Old Apr 9, 2013 | 10:47 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
You need a good set of NGK's one heat rang colder and the correct belt. (1379) or buy them in a package and you know you have the right things.
Chad
Detroit Tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Apr 9, 2013 | 10:51 AM
Jaydavid's Avatar
Jaydavid
Ok thank you both very helpful
Old Apr 9, 2013 | 10:55 AM
ZippyNH's Avatar
ZippyNH
Sure the outmotoring site is fine...bought a few things from them...
Stock plugs for stock pulley, cooler or colder for the reductions.
I hesitate going to some of the big box places cause sometimes they are incompetent...a while back a person had a thread...got some kind of fuel saving plugs that were getting advertised a bunch at the time....(e-50 green plugs or something) was given the "cooper" ones for an S....struck the top of the pistons...wrecked the motor when the piston was damaged....
Thats why i do not hesitate to use our vendors.....and know 2 different ways to get the same part # when i get them locally to be sure!!
Old Apr 9, 2013 | 11:14 AM
Jaydavid's Avatar
Jaydavid
Very very true i could have done that lol not shure it would have saved me much $ but i didnt even consider that thanks again
Old Apr 9, 2013 | 11:57 AM
BlwnAway's Avatar
BlwnAway
NGK's
Stock-BKR6EIX
1 step colder BKR7EIX **What You Want**
Old Apr 9, 2013 | 12:25 PM
Braminator's Avatar
Braminator
Order a set of NGK -4285.
Old Apr 9, 2013 | 12:28 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Check out our WMW pulley package, it has the pulley, belt and plugs.
We don't recommend the Iridium plugs as they wear out and fail too often. Our kit includes the reliable JCW plugs.
Old Apr 9, 2013 | 04:58 PM
uromini's Avatar
uromini
Picked up the Brisk Silver plugs from Alta.. haven't installed em yet but research showed pretty good reviews.
Anyone have any history or experience with em?
Old Apr 9, 2013 | 05:24 PM
Braminator's Avatar
Braminator
Just make sure you torque them down and check them often.
Old Apr 9, 2013 | 05:30 PM
Jaydavid's Avatar
Jaydavid
Ok and with these i dont gap them correct? just tourqe them down correctly with a tourqe wrench then im done? I got the colder range ngk irduim IX plugs
Old Apr 9, 2013 | 05:33 PM
Braminator's Avatar
Braminator
Which NGK? Four prong?
Old Apr 9, 2013 | 05:40 PM
Jaydavid's Avatar
Jaydavid
It doesnt give a part # on outmotoring that i can find so im not entirely shure i pretty much went off of what they offered nd what ive heard i heard ngk was good so i got those and get a range colder which i did i honestly dont know very much about plugs all i know is pull them out and tourqe the new ones in
Old Apr 9, 2013 | 05:45 PM
Jaydavid's Avatar
Jaydavid
From the picture i only see one prong
Old Apr 9, 2013 | 05:56 PM
Braminator's Avatar
Braminator
They should be pregapped.
Old Apr 9, 2013 | 09:04 PM
WayMotorWorks
Vendor
You do NOT gap the 4 prong plugs, if you try you will ruin the plugs.
Old Apr 9, 2013 | 10:12 PM
BlwnAway's Avatar
BlwnAway
There is no need.to gap the single prongs either, come pre-gapped.
Old Apr 9, 2013 | 10:13 PM
Jaydavid's Avatar
Jaydavid
Perfect thts all i needed to know thank you
Old Apr 9, 2013 | 10:41 PM
ZippyNH's Avatar
ZippyNH
ngk irduim IX plugs
are a single prong Iridium....
The tip is very brittle, and TINY, do not try to gap!
Have used them since my pulley install, no issues.
Old Apr 9, 2013 | 10:47 PM
ZippyNH's Avatar
ZippyNH
Some info from the NGK website
Stock S plugs
2005 MINI COOPER S 1.6 L4 W11B16A FI Supercharged
Spark Plug
Part No.
Stock No.
Plug Gap
Standard BKR6EKUB
7969
.032
V-Power BKR6E
6962
.032
G-Power BKR6EGP
7092
.032
Laser Platinum BKR6EQUP *
3199
.032
Iridium IX BKR6EIX
6418
.032
The stock style plug
vs the IX
maniacalmorgan
Jan 1, 2020 11:20 AM
blackie
Jan 18, 2017 09:56 PM
Oct 7, 2015 08:52 AM
bigserb3
Aug 31, 2015 09:54 AM
yashmack
Aug 15, 2015 10:16 AM
