Suspension Squeak suspension
Old Apr 6, 2013 | 02:51 PM
HFDZDN's Avatar
HFDZDN
Squeak suspension
I got into an accident 2 weeks ago , got my hotchkis LCA since the OEM ones were dent and cracked . Set up my alignment and camber blablala. Now it has a very bad squeak , not that this happened after i install my hotchkis's , since the accident it was this bad but the first day i installed the LCA (before alignment and camber adjustment) it wasnt this bad . Bushings are all fine since they're new . Could this be my springs or shocks ? Currently using h&r race spring .
Old Apr 6, 2013 | 02:55 PM
submitaweasel's Avatar
submitaweasel
Ball joints.
Old Apr 6, 2013 | 03:01 PM
HFDZDN's Avatar
HFDZDN
Originally Posted by submitaweasel
Ball joints.
They have ball joints for rear?
Old Apr 6, 2013 | 03:38 PM
timtim's Avatar
timtim
Just to be sure... you are talking about a squeak in the rear suspension, right?
BTW, do you have poly bushings?
Old Apr 6, 2013 | 03:43 PM
HFDZDN's Avatar
HFDZDN
I use the ones that came with the lca (hotchkis). Yes in the rear suspension
Old Apr 6, 2013 | 03:58 PM
timtim's Avatar
timtim
What about poly bushings? A while back I had a most annoying sweaking the rear and turned out to be dry poly bushings on my sway bar...
Old Apr 7, 2013 | 09:43 AM
submitaweasel
Guess I should read the whole post I'd agree with the other that its most likely bushings since its in the rear. I haven't heard of springs or shocks doing this but hey I could be wrong. You said you were in an accident so unfortunately it could be any number of things..
vulkandino
Oct 31, 2015 08:29 PM
torpeau
Oct 8, 2015 11:10 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Emnotek
Sep 29, 2015 07:37 AM
