Rear Brakes Rattling Bad
Old Apr 5, 2013 | 11:08 PM
miniC00PERs's Avatar
miniC00PERs
I have an 03 MCS, and I had recently bought drilled and slotted rotors.
Rears were warped and while waiting for a new set, I purchased some OEM rotors to get by on.
Long story short, I ran into a problem with with my rear brakes, the drivers side was rattling bad. It sounds like there is no pressure on the pad at all. However, when applying the brake, noise goes away, on a lift, brake grabs. E-brake holds on that specific wheel as well as the passenger side.
I really don't want to just start purchasing parts and guess and test.
What is really worrying me, is that my lower control arm on drivers side is slightly bent. It's nothing noticeable to the eye, but it is tweaked a little. It was tweaked before the problem though. However the pads didn't start rattling until I hit a speed bump!
Any input is appreciated! THANKS!
Old Apr 6, 2013 | 04:13 AM
twocute's Avatar
twocute
Try putting some anti-squeal goo on the back of the pads. It helped my '04 with the same problem.
Old Apr 6, 2013 | 07:20 AM
miniC00PERs
I put them on with the pad change. This *rattling* is alot of rattling. It sounds like the pads are just flopping around in my caliper, just slapping against my brake rotor.
Old Apr 6, 2013 | 08:02 AM
Eric_Rowland's Avatar
Eric_Rowland
Did you make sure the inner pad is clipped on to the piston? It's a common issue.
Old Apr 6, 2013 | 10:07 PM
miniC00PERs
honestly...no, but i didn't think of that because the old ones just fell out. i thought they clipped themselves when you put pressure on the piston! thats definately going to be the first thing i check tomorrow! thanks alot!!!
Old Apr 7, 2013 | 08:24 AM
Capt_bj's Avatar
Capt_bj
no they don't just press on IME
you need to slide the pad onto the piston from the open end so the clips engage
Old Apr 8, 2013 | 07:13 AM
+1 on the slide method the two side metal wire /springs grab the slotted head of the piston as well as the bottom metal wire / spring. Open slide of course.
Here is the picture of the rears pads:
http://www.ecstuning.com/Search/34216762871/
Here is the head of the piston: make sure its clean / rust free, so the pad clips set in easy.
Also, check and make sure you did not lose the
Retainer Clip - Rear
http://www.ecstuning.com/Search/34216762749/ES60416/
Thanks and hope that helps.
Old Apr 8, 2013 | 07:47 AM
ashchuckton's Avatar
ashchuckton
^^^ Mr. BJ is correct & it's my thought too. Seen it happen before.
Old Apr 10, 2013 | 08:06 PM
miniC00PERs
it was both problems! I slide the pad on. The brakes quieted down a bit. Took wheel back off, noticed retainer clip was only touching top side of caliper and not bottom side, so I bent it just a small amount and that stopped the rattling. I get a very faint squeak now :( I've driven 400 miles already, I guess the clip needs a little more adjusting but thanks for all the help!!!!
Old Apr 11, 2013 | 08:34 AM
Great news. Glad you got things fixed. When doing a brake job the outside retainer clip retains tension on the caliper to carrier.
Old Apr 22, 2013 | 09:12 PM
miniC00PERs
update, brakes are still squeaking at all times again. it was quiet, at least i thought, for a few days and got loud...not making any flopping noises anymore, however, non-stop squeaks are making me angry!!! i've had these brakes apart, probably 8 times in a month.
Old Apr 22, 2013 | 09:23 PM
minitec22's Avatar
minitec22
There is a lubricant you can get to put on your pads and rotors to help stop the squeaking.
Old May 23, 2018 | 07:52 PM
Minibeagle's Avatar
Minibeagle
Once again, NAM has taught me something. This community rocks
sevin
May 2, 2026 06:11 AM
W0TM8
Dec 19, 2019 07:50 AM
aldito2
Nov 25, 2015 09:33 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
