Service life, Clubman S spark plugs.
Old Apr 4, 2013 | 04:51 AM
Reebus's Avatar
Reebus
What is everyone experiencing as far as the life of your spark plugs? When did you replace yours?
Old Apr 4, 2013 | 05:27 AM
Salbotehcow's Avatar
Salbotehcow
I just replaced mine on my 07 MCS @ 33k. They did not look bad at all, and I think the factory spec is 40k. So use your own judgment. I spent $62 on plugs and $17 on the socket from WMW. Took 45 min, DO NOT pay a dealer $250+ to do this service!
Old Apr 4, 2013 | 06:58 AM
richardsperry's Avatar
richardsperry
Plus for an "S" are 60K mile items, the JCW is 30K. (not that changing them early is a bad thing...)
Old Apr 4, 2013 | 10:40 AM
Salbotehcow
Sorry about the miss-information. To many number bouncing around in my head.
Old Apr 4, 2013 | 04:59 PM
Reebus's Avatar
Reebus
Yeah, the reason I ask is that I have noticed a slight 'stutter' at cerrtain acceleration points. I had my oil changed at the dealership (yeah I know.... Im lazy) and there were no codes. I had a VW 1.8 turbo that would eat them up about every 30,000 miles and was just wondering if ours were the same way. .
Old Apr 4, 2013 | 08:20 PM
boOst spIKe's Avatar
boOst spIKe
That could be a bad coil or an intermittent failing coil due to damaged boot that may have or has gone unnoticed. I've seen this many times, vehicle will idle fine and even @ low rpm/cruise be ok but @ load or @ 70% throttle @ specific RPM's vehicle will experience random break up or "stutter" as you put it.
Aug 27, 2015 10:00 PM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
Aug 19, 2015 12:51 PM
Getrieben
Aug 15, 2015 09:09 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
