Drivetrain What is this? (Intake baffle?)
Old Apr 3, 2013 | 08:35 AM
Hujan's Avatar
Hujan
While putting in an aFe panel filter in the airbox this morning, I noticed this waffle-like baffle in the turbo inlet hose right where the hose connects to the airbox. It is right at the mouth of the hose before you even get to the MAF.
What is this thing? My best guesses are either something to add turbulence to the intake air to help the MAF do its thing OR that is is a baffle to reduce noise. If the former, I'll leave it be. If the latter, I wonder if removing it might add some blow-off and intake sounds to the factory airbox.
Old Apr 3, 2013 | 08:45 AM
bmwr606's Avatar
bmwr606
to keep small birds and mice out of the turbo? lol
Old Apr 3, 2013 | 09:03 AM
Hujan's Avatar
Hujan
Oh it's gone, then! Birds add ~5 HP. (You lose a little low-end with mice, but gain ~8 HP up top.)
Old Apr 3, 2013 | 09:12 AM
bmwr606's Avatar
bmwr606
how deep is that baffle? can't tell from the photo
if it is thin, i can't see it doing anything to the airflow
if it is ~1/2" or more then it could be smoothing the airflow before the maf
just guessing
scott
Old Apr 3, 2013 | 12:00 PM
Hujan's Avatar
Hujan
My guess is 1/4 to 1/2 inch. I've seen a lot of talk on BMW forums about similar baffles and the consensus is that it is to reduce noise.
If some aftermarket intakes replace that hose, it might be safe to assume it is superfluous. I'm reluctant to assume, though
Old Apr 4, 2013 | 08:53 AM
y8s's Avatar
y8s
it could be all of the above.
* prevents large items from getting sucked into the turbo
* straightens out the airflow for better distribution (though before a turbo, why?)
* increass turbulence to reduce boundary effects of the tubing and improve flow
Old Apr 4, 2013 | 02:08 PM
Hujan's Avatar
Hujan
I'm not sure how that waffle would be necessary to keep large items out of the turbo. The object would have to go through the front grille of the car, through the snorkel, past the panel filter, then down the inlet pipe. It seems to me that the grille and panel filter would keep anything out of the turbo?
If it's there to prevent pieces of intake system from breaking off and going into the turbo, I'd think it would be the very last thing before the turbo, even after the MAF (since the MAF could theoretically break off and get sucked into the turbo).
My money says it either improves flow in some counterintuitive way (like dimples on golf *****) or is a measure intended to reduce noise (like the muffler on the hot side pipe to the intercooler).
Old Apr 10, 2013 | 12:21 PM
polojcp's Avatar
polojcp
I am interested in finding out about this as well. Of course I don't expect any power gain, but more interested in creating some noise.
Old Apr 13, 2013 | 12:02 AM
SFWD 1934's Avatar
SFWD 1934
Air straightener for the MAF. Makes the air less turbulent before the sensor. Other types of air straighteners like this would be something most have probably heard of before. Honeycomb. It is much more essential if you were to upgrade MAF housing to say 3" ID. When you start to get larger ID MAF housing your STFT and LTFT can get really skewed and start to pop codes on you for lean idle, etc.
Jason
Old May 16, 2013 | 04:20 PM
demon510's Avatar
demon510
It is an "air straightener" or it creates laminar air for the MAF. It is always a honeycomb construction that just smooths it out for accurate MAF readings.
Filmy
15
Jun 6, 2023 06:27 AM
67morris
May 7, 2016 11:52 AM
Sep 22, 2015 02:05 PM
Sep 11, 2015 11:09 AM
Richard Kellstrom
Sep 4, 2015 07:21 PM
