Where is the relay for the headlights?
Old Mar 27, 2013 | 10:19 AM
skip02's Avatar
skip02
My headlights are doing weird things. When I turn on my clearance light they all come on including the interior lights, however when I turn my headlights on none of the lights will turn on except the highbeams and they don't stay on unless i hold the switch on. I'm thinking maybe a relay and/or a fuse but i cant find the headlight relay.
Old Mar 27, 2013 | 11:06 AM
strobeyprobey's Avatar
strobeyprobey
There is no relay. All of the lighting is controlled (almost every bulb has its own circuit) by the FRM module.
Sounds like that module is bad or wet, or the wiring harness is damaged or shorting somehow. The module is beside the trim panel to left of the dead pedal in the driver's footwell. Pull off the plastic panel and inspect the wiring and the module.
If that looks okay, then it is time to hook it up BMW diagnostic software to see what errors have been recorded.
Old Mar 28, 2013 | 05:27 AM
skip02's Avatar
skip02
So I checked it out and everything looks fine. I might just get the module fixed and see if that fixes it because my closest mini dealer is 1.5 hrs away and its off the road for a while anyway. And I think I can get the module fixed for $60 which would probably be cheaper than getting it checked by the dealer?
Old Oct 18, 2024 | 01:07 PM
rostki's Avatar
rostki
2004 Mini Headlights
Left one works on bright only. Right one doesn’t work at all. Replaced both headlight assemblies. Still same problem. I’m stuck. Any idea? Thank you. Rostki
Zephyr1
Electrical
365
Mar 24, 2026 07:59 AM
tkd540
Jun 9, 2024 07:13 PM
tnitties1
Mar 21, 2022 08:17 PM
pckrwnnb
Feb 6, 2018 07:31 AM
BEAVR
Nov 20, 2010 03:17 PM
