Mold or mildew smell in defrost mode?
Old Mar 27, 2013 | 09:36 AM
julesagogo's Avatar
julesagogo
I have a 2010 MC that I bought new 10/2010 - it smells strongly of mold when I hit the front defrost air blast button (winter, summer - whenever I need to clear interior fog).
I mentioned it at the last service and they exchanged my mold smell for a much worse baby-powder-on-steroids smell. That's thankfully gone, but now the mold smell is back.
Is there a technical bulletin or non-smelly solution for this problem? I'm allergic to mold and have noticed that while I don't smell it when just the heat or a/c is running normally, I've had more low-key sinus/eye issues since I bought the car.
Thanks in advance!
Old Mar 27, 2013 | 09:47 AM
Braminator's Avatar
Braminator
Have you changed the cabin filter? You can try this http://shop.advanceautoparts.com/web...14922|L2*15020
Old Mar 27, 2013 | 09:58 AM
NJ Mini's Avatar
NJ Mini
I'd start with Braminator's suggestion and change the filter first. Then I'd follow up with 1Z Einszett Klima-Cleaner. You can find it at Autoality.com or Detailersdomain.com. You basically just run your climate control on high and place a can of this cleaner near the footwell air intake for the climate system. Open the can and it gets drawn in and cleans the ventilation system.
Old Mar 27, 2013 | 11:08 AM
strobeyprobey's Avatar
strobeyprobey
I third the recommendations of both using the air disinfectant spray and replacing the cabin filter. You can order a filter from ECS Tuning or get from your dealer and pop it in.
My MINI (and a couple of other cars) were suffering from this bad smell and the spray took care of it.
Old Mar 27, 2013 | 11:29 AM
+1 on the cabin filter. Once you get the old one out inspect the cabin box and make sure there is nothing else in there. Then give is a good spray.
Recommend the active carbon cabin filter after you are done.
http://www.ecstuning.com/Search/64319127516/
Old Mar 27, 2013 | 11:57 AM
julesagogo's Avatar
julesagogo
Thanks guys! I looked over my July invoice and they replaced the cabin microfilter, ran Valvoline Heat & A/C cleaner into evaporator in two 10-minute segments, then used a "special" Valvoline deodorizing formula inside the intake vents. I called and the tech suggested BG as an evaporator cleaner.
I found a video showing how easy it is to replace the filter: youtu.be/Y63iLutLNzY but am still searching for the thorough cleaning method for the evaporator. The tech said the water that comes out is black and disgusting, so I'd like to try cleaning that without a deodorizer smell. Any ideas? I am somewhat mechanically inclined.
The reviews online for the Interdynamics product aren't great, but I'd try a well-reviewed easy-to-use product if I could find it.
Old Mar 27, 2013 | 12:56 PM
NJ Mini's Avatar
NJ Mini
I still think you won't find an easier one to use than Klima clean. The system does a the work and is automatically drawn in. You just open the can and leave it. The sprays will only reach so far and to really clean it you would have to run the hvac while spraying and suffer ingesting the cleaner. Just my $.02.
Old Mar 28, 2013 | 01:24 AM
krim's Avatar
krim
I had that dirty sock smell whenever the fans ran. The dealer changed the CAF when maint. was still valid and it didn't go away. Went back, and the dealer did a cleaning of the ducting. Not sure what they used, but they had to drill a small hole for injection. IIRC, it was a $70 service, which was waved under the maint program.
drrigg
May 27, 2022 03:31 AM
bctf1
Jan 2, 2016 04:02 PM
potterstein
Oct 2, 2015 09:30 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
gnhovis
Sep 28, 2015 04:07 AM
