Car having start issues
Old Mar 24, 2013 | 05:28 PM
sirr6's Avatar
sirr6
I've been having an issue with my car first starting up for a few weeks now, it only happens when the car is first started in the morning, I start the car and it dies, takes a few tries and some gas to keep the car running, once its warmed up it seems ok, I called Mini in regards to this, and they said it can be a carbon build up or some kind of high pressure problem???? Any suggestions? Its an 07 Cooper S with only a intake and boost installed. I dont feel like paying them 700+ to do a carbon clean.
Old Mar 24, 2013 | 09:17 PM
boOst spIKe's Avatar
boOst spIKe
Could be HPFP failure. Could be both, if its the HPFP it will be covered under warranty as long as your under a 100k in mileage. I wouldn't be surprised if its both, especially an 2007.
Old Mar 24, 2013 | 09:32 PM
psichick's Avatar
psichick
you installed this in your car?
or a bar of boost?
Old Mar 24, 2013 | 09:46 PM
sirr6's Avatar
sirr6
Boost gauge. Nothing else. What hpfp? I drove it again and the first start sounded like the battery was not good but I know it can't be that since it was replaced a year ago, this time it didn't die out since it was in the sun, seems like it happens when the car is cold. Once I drove to the store, it started like normal and drove normal. Is it worth taking to mini?
Old Mar 26, 2013 | 03:47 PM
mini_mini's Avatar
mini_mini
Same problem here..
i think it s the high pressure fuel pump
Old Mar 26, 2013 | 04:00 PM
sirr6's Avatar
sirr6
Mini. Did u get ur car fixed? Mine usually happens when it's cold, but once the car warms up its fine.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Lt. Dan
Aug 10, 2015 12:46 PM
tippin
Aug 5, 2015 08:43 AM
veevsato
Aug 5, 2015 04:42 AM
