R56 11' R56 N18 obd2 data logging software? similar to VAG-COM?
Old Mar 23, 2013 | 04:47 AM
MDub's Avatar
MDub
Ive got a 2011 r56 n18 engine cooper s turbo
Greetings, I come from the world of VAG (volkswagen)...i was wondering, what are you guys doing to log your cars via obd2 port?
For vw there is a tool called vag-com, it is the official data logging tool for vw's...it gives you acces to all control modules, measuring blocks, self adaptions, output test ect....with this tool you can also reprogram things on the ecu via laptop....things like headlight brightnes, daytime running lights, washer motor delay, windows up via key fob ect, disable seatbelt chime...
Is there an official data logging tool for our mini's similar to VAG-COM?
I need something that will let me
log measuring blocks
Maf sensor G/S
Fuel trim adaptation shrt and long term
lambda afr
boost pressure request/actual, wastegate duty cycles
throttle body angle
ignition timing
timing advance
knock sensors
Fuel rail pressure
Injector timing
Basically everything....
Also something that will allow me to perform self adaptations on the throttle body, tumble flaps, headlight self leveling ect...
Any former vw guys plz feel free to chime in, thanks in advance!!!
Old Mar 23, 2013 | 07:55 AM
MDub's Avatar
MDub
Well something that'll allow me to data log the essentials
Air to Fuel ratio (lambda)
Boost pressure request and actual
wastegate duty cyclea
throttle body angle
Cam/ignition timing
Becuase there is no current support for obd2 tune flashing on this platform, i plan on taking things into my own hands and cracking the wastegate a little or maybe running a manual boost controller in parallel with the n75 valve as a way of controlling boost...
But to safely do this i need to log log log....i just have no idea what to use for this platform....i did a search and couldnt come up with anything...any help would be greatly appreciated....thnx!
randeez
Sep 15, 2015 09:16 AM
Zettinger
Aug 25, 2015 04:04 PM
ShadyCoop
Aug 18, 2015 04:26 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
