window problems 2009 cooper clubman
Old Mar 22, 2013 | 03:50 PM
chappy8599's Avatar
chappy8599
I have a 2009 mimi clubman and i am having trouble with the right side window. it is not closing right. it goes up but somtimes will come back down and stop. and it is not sitting correctly against the 3rd door. someone said the computer need to be reset.. any help..
Old Mar 22, 2013 | 06:15 PM
Braminator's Avatar
Braminator
You can try this:
Instructions
  • 1 Insert the keys and turn on the ignition. It does not matter whether you start it or not.
  • 2 Put the window all the way up (if you are able).
  • 3 Press and hold the window switch in the up position for 10 or more seconds. Do this with the door closed.
  • 4 Open the door to make sure the window drops as it should. Close the door to make sure it goes back up again.
Old Mar 23, 2013 | 06:05 AM
chappy8599's Avatar
chappy8599
You can try this:
Instructions
That worked thanks. One more thing I keep getting a triangle with a snowflake on my display what is this?
Old Mar 23, 2013 | 06:55 AM
John A Shook's Avatar
John A Shook
Warning with snow flake
The car is telling you that the temperature is below 37 degrees and to be aware of ice on the roads.
Old Mar 23, 2013 | 08:09 AM
chappy8599's Avatar
chappy8599
This is my first mini this is all new to me. Anything i should look for its a 2009 clubman with 56000 on it.
Old Mar 23, 2013 | 11:52 AM
fr0mmagna's Avatar
fr0mmagna
User manual. ;-)
Old Mar 23, 2013 | 12:08 PM
chappy8599's Avatar
chappy8599
Originally Posted by fr0mmagna
user manual. ;-)
lol thanks
Old Mar 23, 2013 | 12:35 PM
Braminator's Avatar
Braminator
Here is the manual
https://www.northamericanmotoring.co...top-manual.pdf
Old Mar 23, 2013 | 12:58 PM
chappy8599's Avatar
chappy8599
I have one but thank you do much. By the way the top front corner of the passenger window is not sitting in the gasket like the drivers side is this something wrong
Old Apr 5, 2013 | 05:12 PM
chappy8599's Avatar
chappy8599
How do u adjust the window track on the passenger side of my clubman?
Sexual Chocolate
Mar 31, 2019 08:02 PM
Svejk
Feb 24, 2019 12:18 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Ethan Moore
Aug 6, 2015 05:18 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
