R50/53 How do I install this?
Old Mar 22, 2013 | 06:28 AM
leaf_fan_1988's Avatar
leaf_fan_1988
http://www.outmotoring.com/mini-coop..._bushings.html
For the lower motor mount, how do I extract the original oem rubber bushing, and how would I get this one in?
I was going to buy a BSH motor mount, but for a fraction of the price, I could get just the inserts and reuse the old hardware. I'll do anything to save half a buck.
Old Mar 22, 2013 | 07:18 AM
Braminator's Avatar
Braminator
Deleted due to error on my part. So sorry for the issues this might have caused.
Old Mar 22, 2013 | 07:24 AM
Helix13mini's Avatar
Helix13mini
No, Bram., I think the parts he listed on OM are the lower dogbone stiffening kit: much easier to install. OP, you'll need a lift or good, safe jackstands. Remove the two 16s that connect the dogbone to the subframe and sump bracket. Then take a prybar between the sump and the sump bracket and rock the motor bottom-to-front and you'll be able to wiggle out the dogbone. Getting it back in with the poly inserts may require removing the bracket. Take your time, you'll get it.
Old Mar 22, 2013 | 07:33 AM
leaf_fan_1988
I just spent more time on google and found this video:
So this insert is to be used over the OEM rubber, NOT in place of it.
New question: If my stock dogbone mount is 8 years old with 100K+ miles on it, will I still benefit from these inserts? or do I need to get a new mount and then get the poly inserts?
Old Mar 22, 2013 | 07:35 AM
Braminator's Avatar
Braminator
You are correct Notice the link for the bushing?
Old Mar 22, 2013 | 07:40 AM
Braminator's Avatar
Braminator
It would be IMO better to replace it at the same time. Chances are it the rubber has cracked.
Old Mar 22, 2013 | 07:41 AM
leaf_fan_1988
link? ...no?
Helix13mini
As a general rule: always fix worn or broken parts before installing performance parts. Always.
Old Mar 22, 2013 | 07:45 AM
Braminator's Avatar
Braminator
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
