Question about offset and the rear fender liner
I'm looking on tire rack at at some different 17" wheels. But some of them have a warning saying "MAY REQUIRE MODIFICATION TO THE REAR PLASTIC FENDER LINER"
For example the OZ Superturismo's which have an offset of 40.
Can anyone enlighten me as to why using these wheels may require modification to the fender liner?
40mm would be slightly further out than stock I think so why would that affect the fender liner?
If you lower your MINI and use a tire size that is taller than stock like 215/45-17 then there is more risk for rubbing in the rear wheel arch area, especially over dips and with a full load.
That wheel size is fine otherwise.
Navigation & Audio Audio system power issues?
jeffbeckhudd
Aug 29, 2015 09:11 PM
Mini'mon
Aug 16, 2015 04:15 PM
bctf1
Aug 6, 2015 12:55 PM
