Power Steering - Pump or Fan?
Old Mar 18, 2013 | 10:18 AM
jbmiller's Avatar
jbmiller
Is there an easy way to tell if the intermittent power steering failure is due to the fan or the pump? I have a 2005 Cooper base model.
Most of the time, if the power steering goes out, turning off the engine and restarting it solves the problem.
Thanks,
Bill
Old Mar 18, 2013 | 10:22 AM
xsmini's Avatar
xsmini
its likely the pump starting to fail. Mine was intermittent for awhile, till it died....
The fan just cools it, doesn't keep the ps pump from working.
Nik
Old Mar 18, 2013 | 10:57 AM
jbmiller's Avatar
jbmiller
I've read a time or two that the fan may be prevented from circulating (rock or other debris) and it shuts down the pump. I don't remember when since it has been a while. This has been going on for over three years but I've just been too lazy to figure this one out.
Old Mar 18, 2013 | 01:08 PM
FrenchyR53's Avatar
FrenchyR53
My PS pump was doing the same thing (mostly when stuck in traffic during summer months) when it would get hot. I would restart the car and all was well until next time. It took almost 2 years for it to die but eventually my pump died. Yours is more than likely experiencing signs of being on its way out. Not a cheap replacement either. I was warned not to go for a remanufactured pump either. Apparently these are pretty common weakness.
Old Mar 18, 2013 | 03:48 PM
heli_guy's Avatar
heli_guy
It is likely the pump. You can check if your fan is not working by checking the fuse. I can't remember the number. Freeing up the fan from debris helped mine for awhile, but eventually the pump completely failed. Mine was intermittent too for awhile.
Thankfully it was fully covered by MINI Canada's extended warranty on the fan and pump (i.e. MINI Canada extended the warranty on those parts). Had it all done in Dec for free! Otherwise, it is pricey unfortunately...
Mine was on an 05 copper cabrio.
Etrain
16
Aug 5, 2024 04:37 AM
Manny_cooper
Sep 10, 2015 11:09 AM
HaveATank
Sep 4, 2015 08:04 AM
coachvminis
Aug 25, 2015 06:58 AM
minipopkart
Aug 13, 2015 05:22 AM
