non runflat tire pressure? 30psi of 35psi ?
Old Mar 17, 2013 | 06:41 AM
SCOOTER_#1's Avatar
SCOOTER_#1
Switched to non runflats and question the 35psi recommended pressure. Do you go with standard 30 psi or mini 35 psi? I have an 05 'S' coupe. Thanks Ron
Old Mar 17, 2013 | 06:54 AM
cristo's Avatar
cristo
Alliance Member
What size wheels and tires, which tires did you go with, and what model MINI?
30 sounds low to me in any case.
Old Mar 17, 2013 | 07:29 AM
r34king's Avatar
r34king
I recommend 35psi for non run flats. Has gotten me the best most even tire wear along with keeping the alignment in check
Old Mar 17, 2013 | 07:55 AM
ZippyNH's Avatar
ZippyNH
If it is the same size tire as your runflats, the same psi usually is fine.
Check the psi on the sricker on your car ...psi ratings are based upon vehicle weight and contact patch....
the psi RATING on the side if the tire is just THE MAX PSI the tire is rated for, not a recommended psi for use....
A racer might add or subtract psi in one psi increments to tweak handling...but you have to start somewhere.....and the recomended psi on the car by the build date is a good start for most folks.
Old Mar 17, 2013 | 08:39 AM
SCOOTER_#1's Avatar
SCOOTER_#1
Thanks for your help; 35psi was my expected response. Put on potenza re97
performance h/v 195/55r16 87v
Old Mar 14, 2014 | 03:42 PM
misstenacity's Avatar
misstenacity
Do you like those tires, so far? My tire place says they can no longer get the G019 Grid model...
Thanks!
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
