TPMS question.
Old Mar 15, 2013 | 07:25 AM
Hochspannung's Avatar
Hochspannung
TPMS question.
So I'm going to switch out my wheels for other wheels with no tire pressure monitors.
The light on the dash doesn't come on permanently if there are no sensors at all correct?
Can the sensors be removed and used again. Or how much are they worth if I try to sell them?
Old Mar 15, 2013 | 07:42 AM
Dozuki01's Avatar
Dozuki01
The light will stay on permanently if you do not have the sensor installed and you can install the sensor on another set of wheels.
Depending on the model year the newer sensor has different part number and will not be compatible.
The info above based on experiences with Gen 2.
Old Mar 15, 2013 | 07:49 AM
Hochspannung
I have an 05 r53. That's odd because I had a 05 ZHP with the tpms removed and the light did not stay on.
Old Mar 15, 2013 | 08:00 AM
Dozuki01's Avatar
Dozuki01
SRY - The info above based on experiences with Gen 2.
Old Mar 15, 2013 | 08:01 AM
6000pounds's Avatar
6000pounds
yes the sensors can be removed and used again. you could do something crazy like not waste time and possible money removing them from your stock wheels and have a full set of spares and buy a second set of TPS sensors. They aren't that much.
Old Mar 15, 2013 | 08:24 AM
Hochspannung
I'm in college and I'm on a tight budget. I'm only buying wheel/tire combo used cause it is about the same cost as new tires. Except this way I get to move up to 17" and ditch runflats. Then sell the x-lites, keep or sell the sensors and recoup some of the cost of the wheel/tire combo.
Old Mar 15, 2013 | 10:17 AM
Capt_bj's Avatar
Capt_bj
You are in Canada so maybe things are different but in the US
an 05 goes not have TMPS sensors in the wheels
the pressure monitor system is based on the ABS system measuring changes in speed of rotation
TMPS with active sensors was introduced during the 07 model year.
Show us a picture of a tire valve stem . . . you can usually tell from that.
Old Mar 15, 2013 | 10:44 AM
Hochspannung
Oh true.. It just looks like a conventional black valve stem? No different than any old BMW I've owned. (E30's, e36, e46's). Ill post up a picture in a bit.
Old Mar 15, 2013 | 11:30 AM
ZippyNH's Avatar
ZippyNH
An r53...gen1 car DOES NOT USE TPMS.
Gen1 cars use the abs sensors to count tire rotations, to calculate the tire size....a sudden change = a tire loosing air, light goes on.
The system must "learn" the new tires and rims when installed...the reason for the reset button.
So ANY RIM CAN BE USED. The car does not use mini tpms. Period.
Old Mar 15, 2013 | 11:39 AM
Hochspannung
Ya someone confirmed that you are correct from a local forum.
Old Mar 15, 2013 | 11:43 AM
Hochspannung
freckles81
Jan 15, 2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
Doc Pain
Sep 15, 2015 11:31 PM
PSU 98
Sep 11, 2015 11:20 AM
renchjeep
Sep 6, 2015 01:54 PM
