R56 R56 Water Pump leak
Old Mar 10, 2013 | 08:51 AM
chappybmode's Avatar
chappybmode
R56 Water Pump leak
I found the water pump is leaking on my R56 it has just over 77,000 miles on it. I have also seen a loss in power on the vehicle. Could this be related?
Old Mar 10, 2013 | 05:57 PM
wedge555's Avatar
wedge555
Did you have the waterpump replaced under the recall on the 2007 - 2009 turbos. If you did not your local mini dealership shoud do this formyou for free. If you have had this done already best of luck to you . I just had to have the thermostat housing replaced on my mini at a whopping 600 $.... At any rate good luck ....
Old Aug 12, 2013 | 10:17 AM
laforze's Avatar
laforze
Would a thermostat housing failing cause the waterpump to fail as well? Reason i ask, I just changed the thermostat housing because I had over heating issues and I had leaking (a lot) by the thermo and seemed to be the culprit. When I got everything back together, I still had leaking but now it was by the passenger side. Looking with a flashlight down through the headlight, there is coolant by the pump now.
20
Jul 1, 2025 01:41 PM
Cereall
Sep 5, 2019 06:05 PM
KrisMiss
Jan 3, 2016 02:02 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Lex2008
Aug 16, 2015 08:33 PM
