R50/53 engin bay spinning noise - washer and bolt-like
Old Mar 3, 2013 | 08:27 AM
paul2005's Avatar
paul2005
Hi all,
Searched the forum for engine noises - lots in there, but not quite what mine sounds like.
It takes the form of a spinning sound coming from the engine.
Best way to describe it is it's akin to a washer spinning on a bolt - a sort of metallic rustle when I put on some gas, but not a friction-type or loud "big" sound: it goes away once revs pick up. I guess that its a worn bearing of some sort, but I'm no expert.
Other than that, it's a great car - R53, 03 plate - with very occasional Chewbacca clutch noise.
Apologies in advance if this has been covered.
Paul
Old Mar 3, 2013 | 08:35 AM
Braminator's Avatar
Braminator
2 things I would check are the belt tensioner pulley and the idler pulley.
Old Mar 3, 2013 | 08:39 AM
paul2005's Avatar
paul2005
ok sounds like a plan - my Mini is due a full service soon including a belt change, I'll have to ask the mechanic to check for these as well. They may as well do these during belt change.
Thanks Braminator
Paul 2005
Old Mar 3, 2013 | 09:13 AM
Braminator's Avatar
Braminator
Good luck and keep us posted.
Old Mar 3, 2013 | 10:04 AM
ZippyNH's Avatar
ZippyNH
The sound you are describing is slightly reminiscent of the sound a sc makes when the water pump pto is very low on oil....then it goes away as the remaing oil is splashed around.
Usually only makes this sound on the first startup....since you make it sound like ut is anytime you are at slow idle, hopefully sonething else!
Old Mar 4, 2013 | 09:20 AM
paul2005's Avatar
paul2005
Just an update
had the alloys skimmed at the BMW dealers today. I mentioned the noise when i booked it in last week. Well i just picked it up but forgot to ask about noise
anyway just drove home and no noise!!!
Old Mar 4, 2013 | 09:59 AM
Braminator's Avatar
Braminator
Old Mar 4, 2013 | 10:10 AM
paul2005's Avatar
paul2005
Braminator
please see my first post ��
Old Mar 4, 2013 | 11:28 AM
ZippyNH's Avatar
ZippyNH
Ditto.......
Kimolaoha
Jul 5, 2023 01:04 PM
blackie
Jan 18, 2017 09:57 PM
blackie
Jan 18, 2017 09:56 PM
makg
Aug 21, 2015 02:49 AM
chicohuahua
22
Aug 20, 2015 11:17 AM
