R56 anyone running 195/45-17 on an 8 inch wide?
Old Feb 26, 2013 | 10:51 AM
korre07's Avatar
korre07
Basically, I have a set of NEU's sitting at home waiting for rubber. I can't decide if i want to run a 205/45 or a 195/45. I'm leaning towards the 195/45 because of the poke these wheels give. and my speedo should only be 3% off which is basically going 58 when my speedo says 60. no big deal. anyone have pics of run a similiar setup before?
pics for clicks
IMG]Name:  13139_10152530308020578_466996713_n.jpg
[IMG][/IMG]
Old Feb 26, 2013 | 11:53 AM
Creeve's Avatar
Creeve
What is the offset?
Old Feb 26, 2013 | 12:04 PM
GEMSTER's Avatar
GEMSTER
It will really depend on your choice of tire. Every tire has a different section width and tread width.
For example a 195/45 17 on Falken 912s is almost like a 185.
A 195/45 17 on Yokohama S-Drives doesnt have as big of a stretch as the Falkens.
You probably want to get a bit more negative camber too.
205/40/17 is also another tire size you can run.
Old Feb 26, 2013 | 01:28 PM
korre07's Avatar
korre07
Originally Posted by Creeve
What is the offset?
et35 all around.
Old Feb 26, 2013 | 02:15 PM
Creeve's Avatar
Creeve
Originally Posted by korre07
et35 all around.
You sure? Looks more like et25 then et35 in those pictures to me.
If they are in fact et35 you definitely don't need a 195. A 205 will be fine. Even at et25 a 205 should be fine.
I ran et30 NUE with 205/40 falken 452s for two years with 0 rubbing.
My setup for this season is 215/40/17 on an 8" et35 (not NUEs).
Old Feb 26, 2013 | 02:26 PM
korre07's Avatar
korre07
the boxes say et 35, but i also thought they stuck out a bit for et35.
Old Feb 27, 2013 | 05:07 AM
minsanity's Avatar
minsanity
Feelin' some stretch?
Attached Thumbnails anyone running 195/45-17 on an 8 inch wide?-streeeeeetch.jpg
Old Feb 27, 2013 | 05:17 AM
Braminator's Avatar
Braminator
Why stretch and have the rim edge exposed?
Old Feb 27, 2013 | 06:39 AM
minsanity's Avatar
minsanity
I'm old enough to realize not everything in life should have reason. This is among those under the 'just because' category. No need to agree nor disagree.
Old Feb 27, 2013 | 07:00 AM
Braminator's Avatar
Braminator
I dont agree or disagree. I just wanted to know why someone would do this.
Old Feb 27, 2013 | 07:09 AM
minsanity's Avatar
minsanity
We're on the same boat, Bram. I dunno what floats theirs either.
Old Feb 27, 2013 | 07:13 AM
minsanity's Avatar
minsanity
Oh, unless one is after some serious low n poke. All in the name & challenge of stance.
Old Feb 27, 2013 | 09:01 AM
MNIPWR's Avatar
MNIPWR
225/35 r17
Old Feb 27, 2013 | 05:50 PM
GOC4RT's Avatar
GOC4RT
Originally Posted by MNIPWR
225/35 r17
That would look dumb on a really low mini with Rotiforms.
Old Feb 27, 2013 | 05:56 PM
MNIPWR's Avatar
MNIPWR
Who knows I don't do stance. But if I had 8" rims I would be running 225s
Old Feb 27, 2013 | 06:01 PM
Creeve's Avatar
Creeve
I test fitted some 225/35/17s on my new 17x8 et35 wheels. They fit fine. I actually thought they looked great on the wheels too. Honestly the only thing that stopped me from running them is they have such a small overall diameter that I didn't think I was low enough to pull them off.
Getrieben
Sep 12, 2024 07:03 AM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
Aug 27, 2015 03:18 PM
TJANK
Aug 24, 2015 06:11 PM
Aug 21, 2015 02:29 PM
