R50/53 Octane booster
Old Feb 23, 2013 | 05:53 PM
wvmtnbiker's Avatar
wvmtnbiker
Octane booster
I own a 2005 S with manual tranny. My question is this: is it safe to add a high quality octane booster to my gas for better performance? I already run premium Shell gasoline but I keep seeing these claims of X amount of HP gains in performance motors.
I hope to have installed a smaller supercharger pulley. But that won't be for a while yet. I am also running an OEM air intake system.
Anyone have any thoughts on this subject?
Thanks.
Old Feb 23, 2013 | 06:01 PM
daflake's Avatar
daflake
Thanks.
Save your money, it won't really do anything for you. Run 93 or higher and you should be fine.
Old Feb 23, 2013 | 06:04 PM
dannyhavok's Avatar
dannyhavok
Here's a general octane booster question that I don't need to start a thread for.
I have access to 94 Octane 99.9% of the time. On the rare occasion that I go on a long road trip, I might not. I'm getting a tune in 2 weeks. Would it be safe to tune for the 94 I regularly use and keep some octane booster in the boot for the rare occasion that I may be stuck with 91? If so, how much of these octane boosters is needed to bump a full 50L tank up from 91 to 94? Does anyone know?
Old Feb 23, 2013 | 06:05 PM
Miniman s's Avatar
Miniman s
We only get 91 down here in Arizona. I only use a booster during the summer when you can get some knocking.
Old Feb 23, 2013 | 08:28 PM
GreekDrifter91's Avatar
GreekDrifter91
waste of money you dont need it. 91 is fine if your stock i use 93 because its all we got around here and the cheapest compared to 91 or anything higher at all the gas stations. (i buy costco gas )
unless your getting tuned for anything higher than (93-104) you dont need it. and you better have a good reason to waste your money for running such i octane gas; like rediculesly high boost.
octane does not add HP it only resists knocking.
Old Feb 23, 2013 | 08:32 PM
Braminator's Avatar
Braminator
An ounce of an effective octane booster should raise your octane rating by 2-1/2 numbers. That is, if you start with 86- octane gasoline, one ounce of booster to a gallon will take it to 88-1/2 octane. One word of caution. Octane boosters decrease in effectiveness as their quantity increases. Just because one ounce gives you 2-1/2 numbers more, ten ounces will not give you 25 numbers. Here's a good scale of just about how decent octane boosters will work:
One ounce/per gallon ¼ 2-1/2 numbers increase
Two ounces/gallon ¼ 4-1/2 numbers increase
Three ounces/gallon ¼ 6 to 6 1/2 numbers increase
Four ounces/gallon ¼ 7 to 7 1/2 numbers increase
A good rule of thumb is that anything over three ounces per gallon is wasted. Some crazies dump in a whole can of booster, thinking they're going to get radical gains. Actually, they'll get a decrease in performance, as excessive ratios can cause the volatiles in the gas to deteriorate and excessive aromatics can make the engine run "heavy," or rich.
Old Feb 24, 2013 | 08:30 AM
dannyhavok's Avatar
dannyhavok
Thanks for the info! Maybe I'll just stick with 91 for simplicity's sake.
Old Feb 24, 2013 | 09:51 AM
Longboard110's Avatar
Longboard110
Here in calif. we can only get 91 octane. My car does have a slight ping and the only booster I have found to work in eliminating it is Lucas oil products octane booster.
Old Feb 24, 2013 | 10:29 AM
ZippyNH's Avatar
ZippyNH
IMO get the tune with the lowest common fuel you plan to use...so maybe 92-93, then when you can get 94 great!!
getting a tune for 94..then having it disappear might result in issues.....
some folks are temped to get a tune on racing fuel....so they car brag about dyno numbers.....kinda defeats the purpose of optimizing the car for running in one regular state IMO.
Mine was tuned on 93...and when I got a tank of 90 ( in the middle of nowhere up in maine one day), it does not run as well..less power...can't say it pings or anything, but I can feel it.
If you read the instructions on octane boost...you need it BY THE GALLON, not by the 16 oz container......to get a usable increase in high-test fuel.
in lower octane fuel, (87) not so much.......
Old Feb 24, 2013 | 09:10 PM
miles_miles7's Avatar
miles_miles7
Don't waste your money on those power drinks for your fuel. A tuner here in Socal recommends shell 91 octane as best of what we have here in California.
Mini ni
Sep 24, 2015 05:42 AM
Shane Wendel
Sep 18, 2015 06:18 PM
12R58JCW
R58 :: Coupé Talk (2012+)
Sep 17, 2015 12:21 PM
USA-RET
Sep 12, 2015 02:58 PM
Filmy
Sep 7, 2015 08:27 PM
