Drivetrain Fault Code P0327 Knock Sensor Circuit Low
Old Feb 19, 2013 | 05:21 PM
Inked469's Avatar
Inked469
My mini went into limp mode today going up hill. Pulled fault code P0327. Didnt see anything posted on the forum about it.
Has any one seen this code before?
I saw that some of the ways to test are:
Check resistance
check voltage 5VDC
and its possible that the ECM has failed. But i'm not seeing any other symptoms faults.
Any suggestions?
Old Feb 19, 2013 | 05:48 PM
countryboyshane's Avatar
countryboyshane
You'd need a wiring diagram of the sensor wiring harness to be sure what to look for. I wouldn't say you have a bad ECU. If that was the case your car wouldn't even start.
Old Feb 19, 2013 | 05:51 PM
Braminator's Avatar
Braminator
The code means-
P0327 - Knock Sensor 1 Circuit Low (Bank 1 or Single Sensor)
P0327 - Knock sensor signal: Electrical fault KS (loose contact) of KS loose
http://www.waymotorworks.com/knock-s...0-r52-r53.html
Old Feb 19, 2013 | 05:56 PM
Inked469's Avatar
Inked469
Thanks,
Got that part now looking at trouble shooting it. I was going to check voltage at the sensor and if its below 5 volts swapping it out.
and FYI when the code was thrown
going up hill around 3500 RPM in 3rd gear around 35 MPH. Only was in limp mode for a few seconds until I stopped at the top of the hill then went back to normal .
Old Apr 8, 2013 | 08:54 PM
MiniGun77's Avatar
MiniGun77
Just got the same code. Anyone know where this connection is? I'm guessing it doesn't go bad often. I ran the last 2 tanks on ethanol free gas. Wonder if that has anything to do with it? I'm also due for plugs and msybe some seafoam.
My code first came on just above 3000 rpm cruising at 80 mph for about an hour in 6th.
My wife felt something similar about a month ago. Light went on and off before I could get it to the shop. Not sure what the code was but I lost a coil. I'm thinking another one is on the way out.
Old Apr 9, 2013 | 05:31 AM
Braminator's Avatar
Braminator
Old May 19, 2014 | 08:19 PM
gatorbait01's Avatar
gatorbait01
Did you guys ever figure out the issue you had? My R56 just did the same thing.
Old May 20, 2014 | 07:30 AM
MiniGun77's Avatar
MiniGun77
Got Same Code. Turned out that I needed a timing Chain Replacement with all associated parts like the tensioner & guide. Also needed 2 two Coils. Still have Knock sensor NB. Check Coils What I thought was turbo lag at 3k RPM's was a misfire. It was there when I first got the vehicle(Preloved) and after the timing Chain replacement. Glad the shop Checked all the Coils as one kept going every few months.
Old May 20, 2014 | 10:02 AM
Inked469's Avatar
Inked469
Mine ended up being a leak in the pcv lines. Causing it to almost stall then when it would catch back up it would knock throwing the code. My engine also would idle really bad after coming off the throttle.
Svejk
Feb 24, 2019 12:18 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:49 PM
scottrn
Aug 22, 2015 07:26 PM
