R56 Help! Waterpump & Thermostat need replacing?
Old Feb 19, 2013 | 04:02 PM
thejonathanpaul's Avatar
thejonathanpaul
So I reside in Jacksonville and on my last trip to Atlanta my mini started to overheat and I noticed minor coolant leak? I took it into the local mini dealership they told me I needed to replace the thermostat and water pump and quoted me at 1500.00$. Fast forward a couple of months now the leak is severe and will not hold and coolant or distilled water for more than a hour and smokes whenever I am at a stop. Would this water pump fall under the recall I have a 2009 mini cooper base. This is nuts I just replaced the battery which was not even 2 years old and now this! I love my mini but is turning out to be a lemon!
Old Feb 19, 2013 | 04:29 PM
jcauseyfd's Avatar
jcauseyfd
That sounds like the regular water pump, which would not be a recall item. The auxiliary water pump was the one that was recalled (just for S models).
Old Feb 19, 2013 | 04:32 PM
thejonathanpaul
Thanks yeah I just wanted to make sure. This really stinks!
Old Feb 19, 2013 | 04:39 PM
DneprDave's Avatar
DneprDave
Is there an independent MINI repair shop near you? They could probably do the job for much less.
Dave
Old Feb 19, 2013 | 04:43 PM
thejonathanpaul
I searched I didnt find any mini repair shop in Jax however I found a european shop who quoted me 600. I also see oil leaking now my friend said it could be a gasket! So many issues grrrr
Old Feb 19, 2013 | 05:00 PM
RobMuntean's Avatar
RobMuntean
$600 is a good price for a MINI. I'd definitely take it in ASAP!
Old Feb 19, 2013 | 06:09 PM
Porthos's Avatar
Porthos
Go to Sam's Automotive off of Parental Home and Beach Blvd. That is a great shop and the lowest labor rates I have ever seen. He works on BMWs and MINIs. Also he charges like $86 an hour plus parts. Trust me I lived a mile from his shop and I got treated great by him.
Old Feb 20, 2013 | 08:29 AM
If you need the parts for the water pump & the thermostat we have those here:
http://www.ecstuning.com/Search/11537534521/ES25098/
http://www.ecstuning.com/Search/11518604888/
I would recommend OEM Genuine Coolant.
http://www.ecstuning.com/Search/82140031133/ES196253/
Thanks and hope you get things fixed.
Old Feb 20, 2013 | 03:56 PM
yyj3869's Avatar
yyj3869
I have exactly same problem as you have. I got 07 base model hits 78k now. Did you have check engine light?(mine didn't have check engine light) and also idle problem (Mine does)? mine also has oil leaks little. I think your friend is right. gasket will be problem.
Old Feb 20, 2013 | 04:58 PM
ocluck's Avatar
ocluck
should get MINI new water pump made of metal!
https://www.northamericanmotoring.co...ist-price.html
Old Feb 20, 2013 | 05:30 PM
ZippyNH's Avatar
ZippyNH
So a couple of months ago you are told to "fix it" and now the problem has worsened....i realy hope your failure to fix the car in a timely manner has not doubled or trippled the price if the fix..high heat, overheating, etc are all VERY bad....might cost you a head gasket, the head or worse. Things break...especially when neglected.
A non mini shop that does work on mini's, often a bmw shop, or a mini only shop like waymotorworks in atlanta...were it broke...will often do the same work as the dealer for 40% or so less, just due to lower labour costs.
Old Feb 20, 2013 | 06:24 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If you were in Atlanta you should have had us do it, our dealers are stealers.
Old Feb 20, 2013 | 08:11 PM
mini coop's Avatar
mini coop
My 2008 had it replaced last fall. My local shop only uses OEM parts and replaced the water pump, timing belt and tensioner for $1,200.00. Depending on the mileage that you have on the car, because its coming apart anyways, the belt and tensioner should be replaced at the same time. If not, this will come up in the future. Save yourself the time and aggravation and have this done also.
Old Feb 21, 2013 | 04:51 AM
http://www.ecstuning.com/Search/11518604888/ES2609120
The above is the metal one, its been verified by MINI , when we get one in the picture will be updated to reflect so. That picture was one of the last ones before the changeover to the metal housing. Has the "11518604888" part number with metal housing.
Thanks and I hope that helps
Old Feb 21, 2013 | 09:23 PM
thejonathanpaul
Indeed I do have the idle issue I am going to get this repaired ASAP I will keep you guys in the loop!
Old Feb 21, 2013 | 09:25 PM
thejonathanpaul
Also could the a/c and heat be effected by this issue?
Old Feb 21, 2013 | 09:29 PM
yyj3869's Avatar
yyj3869
Mine drops about 500rpm after car is warmed up. no check engine light right?
Old Feb 22, 2013 | 12:03 AM
ZippyNH's Avatar
ZippyNH
Heat is from coolant, which is circulated through a mini radiator (heater core)....when a car has been run low on coolant, it tends to get air bubbles in it....stopping the flow of water/coolant, causing heat issues....refilling, then bleeding the system will fix this...once the leak is fixed.
A uneven idle is not a good sign on a car thst has been overheated....often repeatesly or run hot....can point to a headgasket, or other issue due to having been run hot...
Hopefull all is ok and it is just a minior issue, but sometimes issues do not become apparent for a few miles after it has been initally repaired.....
Cereall
Sep 5, 2019 06:05 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
scottrn
Aug 22, 2015 07:26 PM
PSIChocolate
Aug 13, 2015 12:46 PM
kwijmbo
Aug 5, 2015 09:00 PM
