How To Exterior:: How to install GP2 Diffuser
Old Feb 12, 2013 | 06:08 PM
Scooter09's Avatar
Scooter09
UPDATED!
Alright, I installed the new GP2 Diffuser today, and took a few pictures and have some part numbers so people can get it done with little trouble.
First off, the big "debacle" when the diffuser first came out was the six bolts that hold the diffuser tunnels to the support brackets. The part number for those is 07147117693.
Next, some people don't have the "aero" panels on the bottom of their car. The part number for one of those is 51752759385. If you plug it in to RealOEM it will show the parts list for everything you need to get them. You don't need them, but that's how you get them.
There are a couple other pieces needed, if you want, I'll get to that in the instructions.
Here we go:
First, the tools I needed are in this picture:
Next, remove the stock "diffuser". It pops out pretty easy after you remove the two screws on each side and bolt on the passenger side holding on the "diffuser", you won't be reusing the one bolt, make sure to take out the clip it threads in to.
Next, install the diffuser. Just pop it in and put the screws back in on each side. The two brackets circled align with the two holes circled in the second picture.
I used two expanding rivets and a couple washers to put in the holes circled above to hold them in to the brackets, also circled. You can do whatever you want, or nothing it all, but that was my solution. If you decide to get rivets, I recommend these: 07130702966. I apologize in advance if they don't fit, but I'm fairly certain they will.
Next, install the tunnel brackets by removing the two bolts holding the exhaust support and slide the bracket in between the support and the car body. The bolts go back in the same holes they came out of.
The exhaust support has a surprising amount of wiggle room while it's being tightened, this is the part that's frustrating. You may get lucky, or you may have to fit the tunnels a couple times and move around the bracket until everything lines up.
The next three images are for vehicles with underbody panels. I purchased 4 of the same clip sets that hold on the sides of the stock "diffuser".
Put 'U' clips on the underbody panels.
Next, install the tunnels. Put everything on loose and then get everything aligned as you tighten.
And, you're done.
Old Feb 12, 2013 | 11:32 PM
InVisib0L's Avatar
InVisib0L
Old Feb 12, 2013 | 11:36 PM
sooper_cooper's Avatar
sooper_cooper
Great writeup. The diffusers look awesome on your coupe!
Old Feb 13, 2013 | 03:52 AM
BLK-MCS's Avatar
BLK-MCS
Awesome write up.
Can you possibly take a pic showing exactly what you mean with the Exhaust brackets and how it now sits.
thanks in advance
Old Feb 13, 2013 | 05:16 AM
Scooter09's Avatar
Scooter09
Originally Posted by BLK-MCS
Awesome write up.
thanks in advance
I updated the instructions with more detail.
Last edited by Scooter09; Feb 13, 2013 at 06:53 AM. Reason: I sounded like an a-hole.
Old Feb 13, 2013 | 05:22 AM
Scooter09's Avatar
Scooter09
Here's a close up of one of the pictures I posted. It's IMPOSSIBLE to install these wrong.
Attached Thumbnails Exterior:: How to install GP2 Diffuser-image-1864015098.jpg
Old Feb 13, 2013 | 06:02 AM
Kurtster's Avatar
Kurtster
Great instructions. Thanks!
I'm waiting on an order from Outmotoring, and what isn't clear to me which parts of the ones you mentioned, they will or won't be providing. Last post I saw from Aaron said they were trying to ship it as a complete plug-and-play set. If I'll need to order some stuff before it arrives, that's fine but I'm not 100% clear on what I'll be getting from Outmotoring.
I guess I'll just wait until it arrives and see what I'm missing, if anything. Thanks again for posting this. It really does look great. Now I need to check to see if my new 2013 JCW Coupe came with those cool underbody covers on the left and right. Those look like they really help with aerodynamics.
Old Feb 13, 2013 | 06:08 AM
Scooter09's Avatar
Scooter09
Kurt, you will need 6 bolts, part # 07147117693 and two expanding rivets. It's the same expanding rivet used to hold in the wheel well insulation, so your MINI parts guy can find them.
I don't know that OutMotoring has those in stock, but they definitely did not come in the kit I ordered from the dealership, nor are they listed in the parts list on RealOEM.
Old Feb 13, 2013 | 03:46 PM
M'Cooper's Avatar
M'Cooper
Awesome, thank you for doing this DIY.
I can't wait for mine to arrive!!
Old Feb 21, 2013 | 10:50 AM
TerminalVelocity's Avatar
TerminalVelocity
Tag for reference.
Old Mar 2, 2013 | 06:40 PM
Scooter09's Avatar
Scooter09
Updated.
Old Mar 5, 2013 | 12:46 PM
walk0080's Avatar
walk0080
Old Mar 5, 2013 | 02:28 PM
ra2fanatic's Avatar
ra2fanatic
Get mad all they want, just ordered mine from my friend's shop.
Old Mar 5, 2013 | 02:30 PM
fishbulb's Avatar
fishbulb
Great...as if I didn't already have enough Coupe Lust....
That looks stunning, great write up!
Old Mar 5, 2013 | 09:02 PM
Kurtster's Avatar
Kurtster
Originally Posted by walk0080
Great post.
Lots of soon to be GPII owners are probably mad about this.
If they are mad about this their heads may explode if they go here: http://www.minigenuineparts.co.uk/mi...GP2_Parts.html
Old Mar 5, 2013 | 09:06 PM
ra2fanatic's Avatar
ra2fanatic
^yeah....but it can be had at a better price than what they offer. That GP2 wing is stupid expensive considering I'd rather have a 7 point adjustable MINI Challenge Wing painted at half that price.
Porthos's Avatar
Porthos
Where did you get your diffuser?
Old Mar 5, 2013 | 09:14 PM
ra2fanatic's Avatar
ra2fanatic
Ltmw...
Old Mar 5, 2013 | 09:31 PM
Scooter09's Avatar
Scooter09
Me? I got it from the dealership. Kurt got his from OutMotoring.
Old Mar 6, 2013 | 06:47 AM
walk0080's Avatar
walk0080
Old Mar 6, 2013 | 09:08 AM
cesar418's Avatar
cesar418
Great write up!
Old Mar 6, 2013 | 04:59 PM
Tallman's Avatar
Tallman
Fantastic post! VERY nicely done Scooter......
definite spring project.... ...........if I had a JCW rear end.
Old Mar 10, 2013 | 02:52 PM
phantasms's Avatar
phantasms
Can anyone give me any suggestions on getting the diffuser to pop in? It doesn't really seem to pop in. I can get it in there, kind of, then do the other side but then the side I just did pops out. It just doesn't seem secure. Anyone have any ideas? When I push into it the bumper just pushes in. When I push from the back of the bumper it still doesn't seem to really pop in.
Thanks!
Best,
Gene
Old Mar 10, 2013 | 02:56 PM
phantasms's Avatar
phantasms
Nevermind. I didn't realize you had to push it so hard. I don't like going all hulk on it when it's on jackstands. Plus my original diffuser had fallen off months ago so there's all dirt in there now which is making it a pain in the ***. You can say that here right?
-Gene
Scooter09's Avatar
Scooter09
Thanks!
Best,
Gene
Try pressing harder? It should make a pop like a clip is sliding in to place. It should be snapped in as far as this picture, if not, try what I just said.
Attached Thumbnails Exterior:: How to install GP2 Diffuser-image-3095462673.jpg
