Suspension Bilstein PSS9 Replacement Springs
Old Feb 11, 2013 | 06:45 AM
sBox's Avatar
sBox
Since putting on the PSS9s many miles ago, I've cut down three tires at Homestead and would like some recommendations. The PSS9s have 35K on them. They've gotten so soft that I'm rubbing due to body roll on offramps. I could replace the PSS9 springs with something stiffer and read this NAM thread. I'm hesistant to throw them out and go to a FSD/spring combo since I have $1700 sunk in them. Some things to note: this is a DD, but I hard springs on the car at 22K miles (bought from a racer--they were on his race car.) I have camber plates and an adjustable rear sway bar to tweak things.
From the thread, it sounds like a 400/350 might be ok, but I'd like recommendations. Direct replacements would be wonderful
Old Feb 15, 2013 | 10:43 AM
andyroo's Avatar
andyroo
What kind and what size tires do you run?
Old Feb 15, 2013 | 10:56 AM
sooper_cooper's Avatar
sooper_cooper
Look into Swift springs.
Old Feb 16, 2013 | 05:45 AM
sBox's Avatar
sBox
I run the same tire on all four corners, no spacers. I shredded the outside of 1 Nitto NT01 225 17 45 on the rear a year or so ago, then dug grooves into 2 Conti DW 215 17 45's on the front recently.
Old Feb 17, 2013 | 07:50 AM
andyroo's Avatar
andyroo
If you want something daily drivable, 6k/6k (336 lbs/in front and rear) would be a good all around fun, fast, relatively comfortable set-up. Still nice on the track.
Sounds like you need an alignment too...check your toe. I prefer 0 toe, with around -1.75 camber front and -1.5 or so in the rear.
- Andrew
Old Feb 19, 2013 | 03:39 PM
tweiss8's Avatar
tweiss8
Sorry to highjack, where does one purchase swift springs? I hear nothing but good things but can't really find much on them.
Old Mar 18, 2013 | 01:00 AM
esfreerider's Avatar
esfreerider
Originally Posted by tweiss8
sorry to highjack, where does one purchase swift springs? I hear nothing but good things but can't really find much on them.
+1
Old Mar 18, 2013 | 07:03 AM
andyroo's Avatar
andyroo
Turn in concepts is a good shop for swift springs.
Old Mar 18, 2013 | 11:43 AM
sooper_cooper
TrackWorx is also a well known vendor for Swift springs.
melscoop
Mar 30, 2016 06:56 PM
sabjcw
Aug 14, 2015 07:40 AM
minipopkart
Aug 13, 2015 05:22 AM
robyb
Aug 8, 2015 06:04 PM
