R56 R56 Quad Driving Light Kit
Old Feb 7, 2013 | 11:16 PM
SoCal MCS's Avatar
SoCal MCS
Does someone offer a quad driving light setup that puts all four lights even with the bumper?? I don't want to block the airflow to the radiator on top or the inter cooler on the bottom....would be nice if the bumper cover didn't require removal to install the brackets....seen a kit for the R53, but not the R56.
Old Feb 8, 2013 | 03:05 PM
pw4's Avatar
pw4
OutMotoring have a setup like that. I think they're separate brackets. Not sure if bumper cover needs to come off - I don't think so, but Euro spec front is different. Their demo car has the setup - pictures on their site. They even use the fairly large Hella 1000 lights. I used the setup with just 2 lights on my Just-a-Cooper: easy to stop the lights vibrating (just put foam between light and bumper!) but I got sick of having to be careful to park where people couldn't back into the lights.
FYI for my S I went for the 4-light bracket from VIP Custom Parts in Arizona, with smaller Hella 500s. I've had no problems with temperature (I have a gauge) even in 100+ degrees. Just to be extra sure, I removed the black grill panel from the bonnet scoop to get a bit more air into the engine bay. R56s have a clever temp setup with a 2-stage thermostats. They usually run near boiling point but a second stage cuts in for extra cooling if it gets too hot (I've never seen it happen), if you put the aircon on max and if you drive fast.
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
